- August 1, 2008
- MO MO
- 94 & 95 XLT's
With the 12" coils, you have to use 12" shocks. The coil overs I run now are 12", and adjustable for ride stiffness. This is the max size your going to be able to fit using a stock upper tower.
I am searching for another set of 12" 2.0 shocks but with reservoirs. With the resi, it gives better rebound, and faster stroke recovery, which means I can go faster over those rough Mtn passes.
These are a different type of shock altogether. I more then likely will get new coils to match these, and the 750 lb coils will be available too.
All this rests on being able to find a 12" overall 2.0" set tho. So far most I found are 10" or 14". I'm still on the hunt tho. If I can't locate what I want, there is the possibility of doing custom upper buckets using Ruffstuff towers. Still on the fence about that tho.
If you can't wait for my wishy washy undecided self, the QA1's are about $200/ea, and the Eibach's are about $80/ea.
Sorry to hear about the after effects of the adventure. Time for new seats!
