- June 16, 2003
- Humboldt, KS
- 2000 Mounty
2 updates
1- I got the 2nd trans cooler fan installed
While I was down there I was trying to use cigarette smoke to check airflow with only the engine fan. Sitting still, the smoke was dissipating to quickly so i flicked an ash. The belt driven fan sucked that ash clear through the trans cooler and ac condenser and it disappeared. Impressive air flow right there. This was without the electric fans running. I'm happy happy.
so, then the problem.
2-There is a big rubber hood bumper on the driver side, with an oval mount hole to allow water drainage. as luck would have it, I mounted my new cooling fans relay sideways, on the inner fender lining right under that hole. Then it rained real hard. Guess what happened?
