- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Or worse yet, it could lock up and shear the drive gear off. If it is squeaking, it is worn. Don't lube-replaceWrench said:The reason for the bird chirp noise emitting from the drive unit (not the sensor itself) is lack of lubrication on the upper shaft support within the drive unit. When you remove the worn out CMP synchronizer drive unit you will notice the excessive side movement on the upper shaft. If you were to continue to drive your vehicle with the old drive unit you would end up dead in the water at some point as the upper shaft cam would destroy the CMP sensor. The only reliable fix is to replace the synchronizer drive unit. Make sure you understand how to remove and install the drive unit properly before you start the process. Make sure you purchase the right drive unit and alignment tool for your particular year, model, and VIN. Also look cafefully at the interior of the CMP sensor to make sure it is still serviceable.
At BEST, it will leave you stranded when it fails
