- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
I changed the transfer case fluid yesterday. It was only a little bit darker than the new oil, and there was just a little debris on the magnet plug, but no chunks. Nothing alarming for a newer gear driven transfer case. No leaks from the transmission or the transfer case. The hardest part is muscling the skid plate off and on. I used my transmission jack to lift it into place for the install. Sucker is heavy. I messed around with the transmission shift cable to see if there was better routing. B&M shows it for a GM transmission making a lazy circle towards the passenger side, then under the trans to the shifter, which is located on the driver side slightly above the pan. The exhaust routing makes that impossible, so it is all on the driver side in kind of a S. It's clamped in one spot so there is no possibility of it making contact with the front drive shaft. I think all that makes it hard to shift. I messed with it a little, seeing if it shifted easier with any minor adjustments before deciding it was as good as it was going to get.
I was going to take it for a drive to go watch Sarah ride at the ranch. It wouldn't start, just click. I messed around with it for a while and thinking I had a bad starter solenoid again, took off in the Silverado. I got about 1/2 mile away and it dawned on me that maybe I didn't get the shifter all the way forward and it was the ignition lockout. It's always been picky about that. I got home about 30 minutes ago, pushed forward on the shifter and it started right up. I guess I will have to take it for a drive tomorrow.
