Bkennedy's SAS and Rebuild Thread
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Looks good. looking forward to a long term report on the Daystar bump stops.
Hope I got the placement correct. Won't know until I get it to my secret testing area.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Got the passenger side done today. As always seems to be the case, it came out better after learning from the driver side. Plus, there was a little more room to work with.
You can see on the next pic why I chose the radius arm for a strike point. There really is no room any where else without major changes and those Duff RA's are very stout.
I made a crude but effective service tool for the bumps.
I also got lucky. I had removed the frame cross bar I made to hold the front of my trans skid plate to make it more easy to cut out the old bump mounts. When I went to re-install the cross bar, the mounting plate just touches the end of the gusset for the bump can on the passenger side. Did not even think about that cross bar when I made up the gussets.
buford1972
Peoria, Arizona
91 XLT
First off, great thread! I just spent several hours going over everything while covering the grave shift at work for the Christmas break. I think I have the solution to your mushy pedal... well actually, you already stated it in post #1283 . You have the brake lines at your master cylinder on backwards. The front Master Cylinder port goes to the rear brakes and the rear port goes to the front brakes. I went out to the parking garage and verified this on my 91 EX. You'll notice that the master cylinder reservoir is mounted at a slight upward angle. The rear section of the reservoir has a larger available volume of fluid (front disks w/ large pistons) and the front has a smaller available volume of fluid (rear disks/drums with smaller pistons in calipers/wheel cylinders). If you look at the link in post #1281 the picture shows that the first piston activates and pushes the second piston via hydraulic pressure (optimal) or by mechanical contact when nearing the end of its stroke as an O-s**t safety measure. Depending on who you talk to, front brakes perform about 70% of the vehicle braking. What you are experiencing is that the rear disks are doing the primary braking. When the first piston (rear calipers) reaches the second piston (front calipers) you have used up all of the master cylinder stroke which =mushy pedal and weak brakes. This is also why you have had some minor improvement when adjusting your rear proportioning valve.
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
First off, great thread! I just spent several hours going over everything while covering the grave shift at work for the Christmas break. I think I have the solution to your mushy pedal... well actually, you already stated it in post #1283 . You have the brake lines at your master cylinder on backwards. The front Master Cylinder port goes to the rear brakes and the rear port goes to the front brakes. I went out to the parking garage and verified this on my 91 EX. You'll notice that the master cylinder reservoir is mounted at a slight upward angle. The rear section of the reservoir has a larger available volume of fluid (front disks w/ large pistons) and the front has a smaller available volume of fluid (rear disks/drums with smaller pistons in calipers/wheel cylinders). If you look at the link in post #1281 the picture shows that the first piston activates and pushes the second piston via hydraulic pressure (optimal) or my mechanical contact when nearing the end of its stroke as an O-s**t safety measure. Depending on who you talk to, front brakes perform about 70% of the vehicle braking. What you are experiencing is that the rear disks are doing the primary braking. When the first piston (rear calipers) reaches the second piston (front calipers) you have used up all of the master cylinder stroke which +mushy pedal and weak brakes. This is also why you have had some minor improvement when adjusting your rear proportioning valve.
If this is true for our setup, this would explain why I have had so many peddle issues since I did the ABS delete. :eek:
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Thanks for the info. My brakes originally had the front to the front and the rear to the rear. I know the 94 is different (4 wheel abs) than the 91.
Can someone with a 99 verify which MC port goes to which brakes?
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Got the passenger side bump installed. Takes about two minutes. Going to test it tomorrow. Bringing the other inserts and tools to modify (firmness, height, etc..) if needed.
By tools I mean two 9/16" wrenches and my custom Stinger service tool.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Bump tests were inconclusive as I could not find a twisty enough spot to really see how much they compress. Noticed a difference on the whoops type bumps, but not much. I moved them down a little, but I guess my suspension is fairly well dialed in so the bumps don't have to work much.
Drove up on a 3' tall rock, not engaging.
Drove up on a 5' tall rock, minor engagement. Need something pushing up the opposite tire to get front tire to go up in the fender well.
Oh, and why don't my yuppie neighbors understand why I am washing my Explorer in the rain? Why do I have to explain its because all that noise I was making the past few days left it covered with little particles of metal?? Why do I have to explain that since it was raining, and the Explorer was outside, I did not want to have it covered with little rust dots tomorrow?? I mean, isn't it obvious????:dunno::crazy:
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 XL '16 XLT
In reference to your MC. This is my '99, which still has the ABS module( it's just in dummy mode because no front sensors ). You can clearly see the forward facing line goes to the front and rear to rear. Because they are labeled :D
Kirby N.
Colorado Springs, CO
1991 Ranger
I dig the bumps. I think I may need something similar soon. I was thinking the same landing location- thanks for sharing what you have learned.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
I had bump stops on the radius arms where the square turns to tube since I did the SAS. I had to move the bumps forward to clear the cans and have the larger diameter bumps center on the arms. I also wanted to go as far forward as possible to make them more effective. After MLK weekend, I should have a Truckhaven Hills report on the bumps.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Did not like the front bump can gusset on the driver side so it got a redo to better match the other side. Cutting torch is out of OX, so a little work with a reciprocal saw, cut off wheel and even my Dremmel got most of the old stuff out. Easy work to weld in the new gusset. Now both sides have the same gussets on the coil over hoop ends and the bump cans.
Old
New
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Truckhaven bump review:
The Daystar Stinger Bumps did their job. Did not need any adjustment as far as location and internal bushings / spacers. They are limiting the suspension as hoped. They are allowing nearly an inch more compression on hard hits than slow crawler type flex compression.
The pics below shows the approx limits of compression at slow and fast speed hits.
I pulled them both apart and both of the bronze sleeve caps had loosened up at the threads. One each of the poly guides / bumps at the ends of the shafts also loosened. Thread locker on all threaded components now. Foam inserts are showing no wear.
All in all, they seem to perform well for what they are; progressive bumps. The fast hard hits were much smoother than the solid bumps I had before. I think having them mounted to strike the radius arms causes them to be used less, and have less pressure on them when used. Might make them last longer before rebuild. I set them up with a medium insert on the bottom and firm on top. Seems to work, and since the kit comes with two of each, gives me one complete rebuild.
Now, of course, the rear suspension bottoms out much more than the front. Maybe I need a set of these on the rear. Going to keep beating on these for a while to see how they hold up first.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
After reading a posting in Kirby's build thread, I took the Explorer for a drive. Got it up to about 90 on the freeway, which was redlined. It was very smooth at that speed. It is at about 3000 rpm at 70
Kirby N.
1991 Ranger
And I thought I was geared low!
That is cool! Glad I inspired you- I take no responsibility if you get a ticket or a wreck :D
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Yeah, I think its good for the driveline to max it out every so often. I think I have the ideal gear/trans/transfer case gearing for off road, maybe a slightly lower low range, but it works well.
Highway, 65 is a comfortable speed.
Kirby N.
1991 Ranger
Cool. Have you ever done the throttle cable mod? It made a big difference on acceleration.
I like my gear ratio too. I could definitely could use a deeper low range in the rocks.
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
I knew I was under geared but wow, compared to you I have 3.27's..
My 33's with 4.10's is just over 2k rpms at 70 mph... I was thinking of going to 4.88's when I got 35's but maybe I do need to go to 5.13..
Out this way the speed limit is 75 but I tend to cruise at 65-70... 70 works better since it puts me in the power band and at 65 mph I'm far enough out of the power band that I slow down up the slight grades when in OD.
~Mark
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Cool. Have you ever done the throttle cable mod?.
Did that a long time ago. Its cheap, easy, and it works.
Mark, I have 5:13 gears and I think they work great with 35's. With the 700R4 trans it allows much more low speed throttle control.
S let's see your steering box on gen 2 sas Offroad Projects 4
ovrlndr Jay's '92 SAS on F150's Offroad Projects 1
KurtECV The Black Pearl SAS and build Offroad Projects 362
G 2001 ex SAS project Offroad Projects 4
C Chato's '98 V8 Mountaineer SAS build Offroad Projects 4
9 2000 5.0 sas question Offroad Projects 3
F Dana 44 purchased, SAS questions! Offroad Projects 7
L SAS on tons and 40" Offroad Projects 2
SVO42 mushy brakes after SAS Offroad Projects 6
A 2005 sport trac Dana 30 sas (Version 2.0) Offroad Projects 24
madbutcher Madbutchers shitmachine sas Offroad Projects 93
1 D30 sas/soa Offroad Projects 4
F FullBlownModz Dana 44 SAS Build Offroad Projects 18
D Project "Twisted Sister" SAS Front Dana 44, Rear Ford 9" Offroad Projects 46
A Explorer SAS or not for daily driver? Offroad Projects 1
boominXplorer Superduty D50 axle for SAS? Give me your thoughts........ Offroad Projects 7
JTX JTX's Return! 1997 Mountaineer Build Thread SAS/4wd Conversion Offroad Projects 65
CodePoet 1st Gen SAS Toyota Steering Box?? Offroad Projects 3
W Woody's SAS Build Offroad Projects 4
MidnightRebel07 2003 Sport Trac - SAS, SOA started and here's a sneek peek. Offroad Projects 118
I Getting closer to my full width 3 link sas need some help Offroad Projects 5
T Ford explorer sas project Offroad Projects 5
Stic-o 2nd gen SAS steering rubbing on exhaust manifold Offroad Projects 17
A sport track dana 30 sas project Offroad Projects 97
R 2002 Sport Trac SAS rack/pinion Offroad Projects 4
jprentice94 1st gen explorer sas Offroad Projects 20
B SAS for 2002 ford ranger Offroad Projects 0
D dersch6221992 Dana 44 SAS, with a rear SOA Offroad Projects 18
T 99 Explorer 1 ton SAS Trail Machine Build Offroad Projects 10
W 99 mounty sas thread Offroad Projects 0
K SAS to do or not to do? Offroad Projects 4
blueka Pickle 2.0 - Full Width SAS/SOA 4406 swap Offroad Projects 208
D 01 Sport Trac SAS Offroad Projects 33
C 94 explorer. Need help with SAS Offroad Projects 1
Y YoungMounty's '97 Mountaineer SAS Build Thread Offroad Projects 14
N SAS with ABS? Offroad Projects 24
X xeek's full width sas Offroad Projects 74
Stang5lgt Bronco II SAS Dana 30/8.8.... Offroad Projects 7
C Rocky Mountain Ranger '92 SAS Offroad Projects 32
Stang5lgt Project Lazyboy SAS... Offroad Projects 277
M 94 Re-SAS....leafs to links Offroad Projects 7
jjaganashi Gauging interest on SAS Offroad Projects 10
jjaganashi SAS "Betsy" 1-ton Offroad Projects 90
M mjc79's sas project Offroad Projects 7
LIFTEDXPLODER96 oh ya know just another 2nd gen sas in the works Offroad Projects 34
1-MEAN-X Project Green Hornet '01 Sport SAS Offroad Projects 159
turboexplorer Turboexplorer's Full Width SAS Build Thread Offroad Projects 965
D My no-budget 91 Sport SAS Offroad Projects 37
Four0Sport Jack's SAS version 3.0 Offroad Projects 270
C SAS leaf springs front Offroad Projects 2
Similar threads
