Big6ft6
- January 3, 2007
- Madison, WI
- 1997 5.0 AWD
Joe
You definitly have a better understanding then me becuase my head is spinning
. I can understand how having the front ds installed would prevent rolling down a hill, and how with it removed one would need to use the parking break. That I get.
But, to continue with your analogy using a standard rear axle, I don't see how if I held the drive shaft in my hand so it couldn't move and removed one side of the rear axle (we'll have to assume we're using independant rear suspension
) then spun the remaining rear wheel on the remaining rear axle, why would the output for axle I removed spin at a different rate? what would preven it from just spining freely in sink with the rear pinion. In order for there to be damage from slippage, it would need to be turning at a rate other than the otherside of the viscous coupler, I don't see what would make it do that?
But I probably shouldn't even be typing this becuase I have no idea what is under the trucks, I've never even looked under my explorer except to change the fuel filter, I just enjoy thinking about this mechanical stuff!
These kind of torque trasnfer systems have always baffled me on how they would work.
