Just google 5.0 MAF adaptor or go to eBay and you can get adaptors and filters for fairly cheap http://m.ebay.ca/itm/MAF-Mass-Air-F...-Explorer-5-0L-V8-00-/271805400907?nav=SEARCH here's one of many available
Put the stock items back on the explorer. Easiest.Hello everyone. I wonder if any of you have knowledge about my situation. So I did exactly what was mentioned in beginning of this thread. I got a k@n cold air intake kit for a 95 mustang with 5.0. I figured I could modify to make it work. So I had to flip one of the tunes 180° and put MAFS at end by air filter. Also the 97 explorer air intake temp sensor is different style then the 95 mustang. So I got a air intake temperature sensor for mustang and wired that up with male and female connectors, just in case I needed to put stock stuff back on. I made a custom bracket that mounts to corner of MAFS on corner, because big chrome plate that came wouldn't fit. Anyways thats all fine and dandy.
But the issue is that with that high performance intake for mustang thats nearly twice the size and flow. Now the check engine light is on and says it's running lean.
So my question is. What's the easiest way to get more fuel, so it runs correctly with no check engine light?
1. Program Ecu.
2. High flow fuel pump.
3. Adjustable fuel pressure regulator.
4. Bigger fuel injectors.
It was a intake that don't require retuning. But maybe since explorer is not a mustang. I'm kind of on budget, but willing to do whatever is necessary to make it run correctly. I just need to know what I need to do. Please help if you know anything related. Thanks
So there are a few things I want to do.There’s really nothing to gain with a huge intake, and no other mods.
Hello Mbrooks420. So I talked to a friend and they told me the issue is the mustang air intake temp sensor. So I got a brass fitting that will thread into the hole for sensor. It has a smaller threaded hole in center that I can screw the explorer sensor into. So the Ecu was confused, bcus there was a foreign sensor in its system. I haven't put it back together yet. Waiting on exhaust work.I still don’t believe you are having an inadequate fuel supply problem, nor do I think your planned modifications require any fuel system upgrades. The first step is to fix what’s broken about your current setup.
Ranger frames are quite different, and you can’t just can swap them. You’d be far better off swapping the 5.0 driveline into a Ranger.
Simple would be just to put a 5.0 in the Ranger. Simple would be running a factory intake that will make exactly the same power as some Frankintake sourced from other cars.Hello Mbrooks420. So I talked to a friend and they told me the issue is the mustang air intake temp sensor. So I got a brass fitting that will thread into the hole for sensor. It has a smaller threaded hole in center that I can screw the explorer sensor into. So the Ecu was confused, bcus there was a foreign sensor in its system. I haven't put it back together yet. Waiting on exhaust work.
I know that all frames: explorer, Ranger, f150 etc.. differ in many ways. But that's part of the game. My goal is to have a custom 94 Ranger 5.0. There are many ways I can do it. I'm going simple and affordable. I don't mind have some custom welding done, such as moving body mounts or bobing the bed to fit. That is minor in my opinion. I could do drivetrain and engine swap. But that would require rewiring the whole truck head to toe. With way I'm doing it, I only got to do half. There are many reasons I decided to go this route. Thanks for info.
