- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Is there anything josh does not dabble in?
What a team!!!
What a team!!!
It would be arrogant of me to say if I can't do it, it can't be done. It would also be untrue cause I learn something new everyday. Sometimes I have to learn from my own mistakes.Is there anything josh does not dabble in?
What a team!!!
nice vid btw on the intake! need an exhaust clip sometimeYes, I agree Josh. We should definitely avoid being arrogant. Also I also hope to never stop learning. Must of us learn the hard way. That's part of the reason, I started my youtube channel. "Sweet Bailey". To help others avoid learning some things the hard way. On that note, Intake is ALL DONE! NO ISSUES! Also I have posted my video on my youtube about it. I know it's not perfect, but I just do what I can with what I got. Think I'm done with major upgrades for now.
Next Big Project is Swapping front end parts out. It's got bad ball joints and I purchased that TRQ A-arm, ball joint, tie rod, antisway bar kit online. It was only $365.95. View attachment 439269Way better deal then having les schwab change 4 ball joints for $700.
Thanks again guys for all the help! Take care. Later, PEACE!
in general, just an overview of your exhaust, but most importantly... sound!!!!!!!You want me to do a video on the exhaust? I dont have clip of when it was stock. But I could explain about O2 Sensors, Cats and entire system. So am I correct? That these have 4 Cats and Three 02 sensors?
So manifolds, two 02 sensors before, the first 2 cats, One 02 sensor on passenger side i believe, then 2 more cats, muffler, resonator, tail pipe. In that order? If that's correct, then in states with NOT A TON of EMISSIONS REGULATIONS. You can technically remove the last 2 cats without tripping a CHECK ENGINE CODE. Correct or am I wrong?
A spark plug anti fouler on the post cat O2 sensors works wonders.You want me to do a video on the exhaust? I dont have clip of when it was stock. But I could explain about O2 Sensors, Cats and entire system. So am I correct? That these have 4 Cats and Three 02 sensors?
