87MCProstar
- November 24, 2008
What is the option to having a switch placed into the dash for selecting 4wd low/high 2wd lo? This is instead of having the shifter knob near the legs of the driver.
No one has yet done the Sport, but I think it can be done. The gas tank clearance is the only issue, the big BW4406 is close in the 4dr's. In a 2dr, it may take more work like I'm trying to do to get an electronic 4406 to work with a big tank.
Ask the guys who know the trucks better like Jamie, about the length differences between the 2dr and 4dr. Then you figure how much you need given how much clearance others have had with the manual 4406 in there trucks.
I have done the 5.0 swap into my 95 4.0 Ex,which means the 4r70w tranny had to swap in with it as well as the whole wiring system throughout the truck from a 98 mounty.Now i want to do away with the AWD transfer case.I scooped up a TC from the salvage yard out of an F-250 but led to the gas tank concern,so I measured my tank and I measured(4 door) and I measured a random Sport Ex at AutoZone.Icame up with aprox 10" diffrence between the two.I dont fill my tank up all the way anyhow;no sense in carrying around the extra weight when the gas station is always near by, so I'm doing the tank swap.
It would need to be pretty precise. There is very little movement required of the lever on the case to shift it. The shifter linkage effectively "gears down" the movement required. So, you move the in cab shift lever a lot more than the lever on case actually moves.
Great thread, the wireing is very useful. I know 410 had some problems finding the linkage/ shifter parts. I just got mine from Ford, so I figured I'd give you the numbers:
Lower lever (part that bolts to the transmission) F65Z7210BC
Upper lever (the rod in the cab) F65Z7210AB
Rubber boot F75Z7277AA
Linkage (piece that connects to the t/c) XL3Z7B051AA
Hope this helps someone out there looking into doing this swap.
almost done
couple of questions
1. what is the proper fluid for a manual shift 1997 4406 transfer case and capacity?
It should be the same as original: ATF[/COLOR]
2.what boot did you converters use for the manual shifter?
