SupaSwope
- August 5, 2016
- Florida
- 99 Mountaineer 5.0 RWD
Starting the process of my swap for my 1999 Mountaineer 2WD. Total time so far is about 12 Hours and Money at about $370.
Parts Collected:
4R70W /w TC from AWD 5.0
3.73 Front Differential
CV Axels, Knuckles, Hubs, Rotors
Manual 4406
Shifter and Linkage
Front (4.6) and Rear (5.4) Drive Shafts
Front Drive Shaft Shield and Skid Plate
All Nuts and Bolts
Parts Needed:
RTV Sealant
ATF
Possibly Transmission Pan?
Transmission Filter
Extension Housing Gasket?
U-Joint Conversion Adapter ( https://www.summitracing.com/parts/axe-1-0134 )
1. I have some questions if anybody could help answer some simple ones, Do the AWD 4R70W and 2WD version share the same oil pan?
2. Is this U joint conversion adapter the right one I would need? https://www.summitracing.com/parts/axe-1-0134
The reason I ask is because in the thread I am mainly following on the conversion lists an autozone part (Autozone P/N: 185793, PDQ/Brute Force #1-0134 ) That does not show up anymore and there are a few companies that make the same U joint of #1-0134 as the one I listed. Are they the same? Is it okay to order?
3. Also I need help on finding the proper name of the metal gasket that goes between the trasmission and and engine, has the starter go threw it and has bolts go the opisite way of the top 6. Is this the Extension Housing Gasket?
Thanks for the help. Tell me your thoughts.
Parts Collected:
Manual 4406
Shifter and Linkage
All Nuts and Bolts
Parts Needed:
RTV Sealant
ATF
Transmission Filter
