So, I guess what I'm asking is which part of that is the courtesy lights?
Well, you have a great point. I was making an inference that the temporary function of the interior lamps is what is called "courtesy light". That is to say that there isn't a dedicated bulb that is called the courtesy lamp, but when the interior lamps come on for the purpose of welcome / farewell, that is the "courtesy light". I could be mistaken on the use of the term.
Hmmm...the plot thickens...my interior lights most definitely DO come on. Well, let me clarify that, they come on when I actually open the door, not when I just unlock it.
This is VERY interesting, and seems to confirm what I suspected. I did some testing with:
a) Only IPC Silent Mode ON
b) Only BCM 726-32-01 Silent Mode ON
c) Both on
d) Both off
... yeah, kinda nerding out over this
In cases A, B, and C:
unlock via key fob = NO interior nor exterior lamps
open door = NO interior nor exterior lamps
In case D:
unlock via key fob = YES interior and YES exterior lamps
open door = YES interior and YES exterior lamps
You seem to have something different;
open door = YES interior and ??? exterior lamps
The other thing I found out is that case B (and C) allows you to dim the instrument cluster to the point where it is completely off, as long as the headlight switch is in the off position. Case A does not allow this.
