Dannyboy's Re-Registry | Page 11 | Ford Explorer Forums - Serious Explorations
What better time than now to do this.
Here is my old 94
http://www.explorerforum.com/forums/showthread.php?t=100935
Just when my transmission crapped out again, I saw my current 91 for sale on this forum. Joe (Lilmule) owned the truck since new and moved to Milwaukee. When I got this truck I had no clue what I was getting myself into. Honestly, I purchased the truck for the glass fenders and C4/C5 transmission setup. I didn't want to deal with TTB, didn't know who "Autofab" was and didn't like that it was spring under and had some 9" axle that I knew nothing about. Here was the plan, combine these 2 trucks, solid axles, updated glass, C4/C5 tranny, 37" swampers, and ditch the blue truck.
Luckily for me and this truck, I didn't have time to start parting it down. I took it out on a few rides, fully rusted out and couldn't believe the "shalackin" I could put into this truck. I spoke with Joe on the phone a few times over the first year and he kept going on about how great this setup is but never really knocked my solid axle idea or told me what to do. I did start to see that some serious money was spent on this rig the first time it was built.
When Joe mentioned his bill was in the 5 digit numbers at various places like Autofab, Currie/Mogi etc, I realized that I needed to do some more digging into what I had gotten myself into.
Disappointed my 94 that had nearly $30,000 into over the years was sitting dead with transmission parts in a box in the backseat, I researched what I had. I realized that the blue 91 was the truck to move forward with, XL over a Limited means less issues, power features to short out and it had some serious potential. I parted down my 94 and laid it to rest.
The for sale ad even said "Needs TLC, after that..."
and this brings me up to speed.
I ran this truck for a while, my avatar photo was taken without spending $1 on this truck, I couldn't belive taking a truck that was sitting could handle this abuse. This little thing was just a machine.
Then I went to Truckhaven and it was pointed out by other members that I had some work to do, a shackle was nearly rusted through, radius arm bushings were toast, etc. I didn't care, I have a trailer and a tow rig...this trip it paid to have them. I was running a wash and snapped the passenger side u bolts, puncturing the tire and leaving the truck not driveable. I don't even think a trail repair would have gotten me to drive this out.
I still got a good weekend of wheeling out of this truck and still had the attitude that I could leave it behind if something happened to it for how cheap I bought it.
Still considering the Dana 44 I have sitting at my house, I decided that I didn't want to give up the speed. I visited Autofab while in San Diego and John was a very cool guy for discussing a truck he built probably over ten years ago. It was at that point I decided to go forward with the original intention.
One trip to Truckhaven with some new updates such as 33x12.50s instead of 33x9.50s, new spring pack to replace the original 11 leaf spring under pack (which raised the rear of the truck nearly 5" from the tired pack), new brakes, auxilay fuse panel, the bumper from my 94 got me excited making it look like a whole new truck.
It was at this point I got bit bad by the bug. I needed new shocks, the rear was just too bouncy, I was going fast and am madly in love with the lady who loves to ride shotgun so now 2 lives needed to be protected and lots of stuff needed to be fixed to keep up with this speed.
Well, 6 months in the fab shop, the truck has just had it's first run with the "new" setup.
So here is the breakdown
Engine
Ford 4.0
KKM filter
stainless intake
hypertech chip
headers
exhaust
Transmission
C5 3 speed built by Mogi Enterprises with all C4 internals
reverse valve bodied (an auto but you need to manually shift)
Art Carr shifter
B&M tranny pan
Transfer Case
Stock pushbutton transfer case (button in a not-so-stock dash)
spaced back since C5 tranny is much shorter than stock, retaining stock front driveline length
Front End
Dana 35 TTB, AutoFab kit (the $3600 kit before shocks!!!) inlcudes extended radius arms, tranny crossmember, triple shock mount (1 behind, 2 in front) currently running Rancho 5000s but 3 of them keep it in control
16" of wheel travel approx 6" of raised height over stock
4.56 gears-no locker (don't want one)
warn manual hubs
5/8" wheel studs
limiting straps
"Winter" mods on inner axle shaft and passage
Rear End
Ford 9" built by Currie, fully trussed
4.56 gears w/ Detroit quick lock
Disc brakes, Wilwood 4 piston calipers, 2 piece rotors (see writeup)
5/8" wheel studs
Valley Spring Service 11 leaf spring under leaf pack
Total Chaos low profile u-bolt retention plates
King 3.0 16" travel triple bypass piggyback shocks
Aftermarket Shackles
Wilwood brake proportioning valve
Wheels/tires
I've ran several setups, currently running 35" BFG Krawlers on 15x10 steel wheels.
Other Exterior
Perry's 2000 conversion front end, 6" pull fiberglass
4 pin removable fiberglass hood
autofab prerunner front bumper
Dannyboy's designed rear bumper/2" receiver
Rock sliders
2-8" 130 watt driving lights
4 rocklights mounted 2' behind each wheel
Cage
HUNTER OFFROAD custom built roll cage-www.hunteroffroad.com
*all interior gutted for tight fit
*in-cargo shock mount for King shocks
*4 bucket seats incorporated and tied into cage
*ties into frame in 6 positions
*ties into body in 16 positions
*spreader bars
*A-pillar support (required windshield removal)
*1.75" steel and 1.5" (approx 130 feet total)
*Hi-lift Jack mounts, spare front/rear driveshafts, shovel, fire extinguisher mounts
Other work by Hunter Offroad
* removable Aluminum dash assembly
* custom built door skins (required with cage side support tubework
* hood pins for 4 pin removable hood
Interior
4 Corbeau bucket seats
4 Crow 5 point wrap-around harnesses
Auto Meter instrumentation gauges (Tach, Speedo, Oil pressure, Water, Fuel, Voltage, Transmission Temp) see writeup
12 Position Auxiliary fuse panel (see writeup)
Kenwood Receiver
Sirius Stiletto dash mount
Garmin Extrex Legend dash mount
CB radio
Full Recovery & Safety Gear + tools, parts
Here is my 3 step process to access all tools/cargo until I get a tire carrier of some sort built
tools/camping chairs/spare parts safely secured
Spare fluids in tote that securely fits under shock mount.
Tire just barely fits with 10PSI
Not sure where to list this, but I installed my Willwood proportioning valve to get the rear braking under control, can adjust front/rear brake distribution from the drivers seat
ROCK ON! Thanks for looking.
Congratulations Danny!~!!!!!!!!!!
Congrats man!!
Danny, do you have any other pics of your autofab 2-link besides the one on page 8? Maybe how it mounts/where on the frame in relation to the front of the leafs? This is the only truck i've seen with them on a SUA setup. Do they limit droop or bump travel for you? I had to take my stock traction bars off when I put on my new springs, but i'd like to figure out a way to get them back on.
Danny Man, congrats on the wedding!
sorry its such a late congrats, but a sincere one none the less
Ladies & gentlemen, I have a very important announcement. This explorer is now 2,000 miles away from me. Not because I sold it, but because I decided to accept a job in Las Vegas! Allison & I got out here over the last couple weeks. Work is great, it feels great to be back out West and in due time the explorer will make it's way here.
...It's time to start thinking about Nevada runs now...:biggthump
Where's the "like" button?
THIS IS AWESOME!!!! Welcome back friend!!! Can't wait to see you at T-haven:thumbsup: We're talking about doing a Cleghron run soon, so only a 2 1/2 drive from you:D
As Stic-o knows, the truck is back out West. I drove it about 15 miles today, which is the first time I've driven the truck since fall of 2010. It's up for sale out here but also tugs at the heartstrings when I spend time cleaning it up and driving it.
how much?
how much?
He's asking 7k from the flyer I saw. But I'm sure he would make a great deal to keep it in the family;)
You pay the gas I'll flat bed it back behind the SD:D
Yup. Drove it to work the past 2 days. Certainly running very rich. I listed the truck at 7k & personally think it's a fair price considering everything I know it has. It's a bit rough running due to the time it has sat, but it works! Ideally, this truck is ready for 1 more transformation with the cage going all the way forward to the front bumper & a big v8 engine. I'd certainly make someone in the family a deal, i also have considered a part out since there are a lot of great parts on this truck.
If you try posting it to Dezert Rangers and on the Race-Dezert Classifieds you might get more bites. There was actually a guy on DR recently looking specifically for a 4wd explorer. Does it have rear seats?
Sounds fair. I would love to test drive it, but don't need anymore toys hah. Less expenses would be nice. It's sad to realize how long it's been since I've wheeled with you guys :(
Sold the truck last night. It is a sad day, but there is just not enough time in the year. I put about 100 hours on the boats this year, business is booming & baby boy #2 is due in March. Also, moving back down to Phoenix from Vegas as our dealership is growing into a 2nd location.
