- July 26, 2004
- Willow Grove, PA
- '97 XLT
Finally got around to installing my two H3R fire extinguishers today. I'd been running with a small $10 kitchen ABC for years, and seeing as the thought of watching my truck burn away in from of me makes me want to hang myself, I thought I'd upgrade. I got the two extinguishers below:
The black one: 2.5 Halguard Halotron clean agent extinguisher (no residue, no corrosion, etc)
The Red one: 2.5 MaxOut Automotive Dry Chem extinguisher
I decided to mount them on the rear window sills. Because I'd be mounting into the plastic, I made sure the cut heavy metal brackets to increase the support for the mount so it wasn't just screws through plastic. The last thing I want is these things ripping out in an accident and becoming deadly projectiles. I also considered that they'll be in sunlight in the summer and could get pretty hot, but I know a good many people who have interior mounted extinguishers in similar locations without issue. The tint will help keep the sun at bay a bit, if if it's a bad heat wave, I can always cover them or pop them out.
Anyway, onto the install. The white brackets are the ones I created to increase support. Cut them from 1/4 steel and drilled them to match the brackets.
I then lined the brackets up where I wanted them on the sills and drilled.
Dropped the screws through the brackets and the steel braces:
From underneath:
Voila.
Rinse and repeat for the reverse side:
And the finished product:
From underneath:
Voila.
