Front air dam vs Sandjill Crane | Ford Explorer - Ford Ranger Forums - Serious Explorations
While driving about 60 MPH last night, a Sandhill Crane decided to take to flight from the side of the road… directly into the lower front of my Explorer.
He hit the air dam and broke the fiberglass right in the center. I am amazed that there was not more damage to the fiberglass. I am further amazed that the bird got up and took to flight.
When closely examining the air dam, I also noticed some damage to the paint and minor chipping due to “junkâ€￾ from the highway.
Any repair advice is welcomed.
Thanks ………
2000Sportdriver
Gambrills Maryland
2000 Sport
that is not terrible Al,
a skim coat of body filler whould do the trick.
Check out MONMIX's thread Body Work 101
MONMIX
I fix dents
Moderator Emeritus
Millersville , Maryland
2000 Explorer Sport
thanks for the assist 2000 :)
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
to make life easy remove the bumper and set it up on a trash can or something.
It looks like the crack is very shallow. If that is the case just 180 grit sand about one inch in each direction. Press on a thin coat of Evercoat Skim coat.
Sand it smooth.
It may take two or three coats.
Prime.
Paint.
aldive
Elite In Memoriam
1999 XLT
The crack is actually all the way through the air dam. Is your procedure still recommended or should I put something on the back side?
Where do I set the sjim coat product?
Thanks ....
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
Evercoat Skim Coat ( also called Metal Galze ) can be found at any auto body supply shop.
Check your yellow pages.
There is a picture on my body work 101 thread.
If ya have some rigid two part epoxy I would spread some of that on the back side.
There is no need to really fiberglass repair that since it all seems tight together and not a lot of flaking.
aldive
Elite In Memoriam
1999 XLT
Thank you, I really appreciate your knowledge in these matters.
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
you are most welcome Al.
aldive
Elite In Memoriam
1999 XLT
Body repair man I am not.
However, I have spent the last couple hours completeing the rapair to my air dam. I followed Monmix's instructions.
Turned out better than I expected. I shall paint it tomorrow and try to get a picture posted.
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
YAAAAAAAAAAAAAAAAAAAAAAAAAY Al !!!!!!!!!!!! :)
ShinySideDown
you brought beer, right?
The 1st State, Delaware
94 XLT
there's always certifit though, right Monmix?
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
MODERATOR !!!!!!!!!!!!!!!!!!!!
ShineySideDown is using potty mouth !!!!!!!!!!!!!!!! :)
Crankcase
Moderator Emeritus
Moderator Emeritus
Vancouver B.C, Canada
1992 XL Ex-Police
Lol!
BBQ_HotDogs
A Man Without Wheels
Houston, Texas
98 Eddie Bauer (R.I.P.)
Remember Al, those EE airedams are priceless now. No longer in production. So whatever you have to do to save it, do it man. LOL.
aldive
Elite In Memoriam
1999 XLT
So true, Ronnie.
I decided to postpone the paint until I fix all tyhe road dings on the leading edge of the air dam. There is a lot of little areas to repair.
aldive
Elite In Memoriam
1999 XLT
Here are a couple shots of the repair ....
aldive
Elite In Memoriam
1999 XLT
... and a couple of shots after the painting. Note: the bird broken lights have been removed.
j602
resident ******
Dothan, AL
'92 XLT
Looks good, Al. Nice job.
ShinySideDown
94 XLT
LMAO !!!
actually, we just fixed a 2001 civic with their stuff, and it was thicker steel than the factory! :eek:
Repair Looks Good Al!!!
