Front end suspension parts | Ford Explorer Forums
Denver Colorado
98 explorer xlt v8
98 5.0 awd xlt. What parts would I need for a front end suspension rebuild? I’ve already done the sway bar end links and shock absorbers all around. Any help would be greatly appreciated.
A complete rebuild with no compromise or only a repair?
Depends on what you must change and what you like to spend in money/time.
I would not buy such a "cheap complete set", buy good parts seperately.
Upper and lower controlarms with balljoints
Maybe you need swaybar bushings
and new camber/caster bolts
If you don't need new lower controlarms, they are not rusty and rubber bushings are in good conditions,
then you have to press out the lower ball joints.
What about steering, inner and outer tie rods?
Front wheel hubs, no play?
Some information about steering and suspension
Good luck!
Lower ball joints
Upper control arms with new ball joints
Inner and outer tie rod ends
Wheel bearing / hub bearings
Brake rotors calipers pads
Cv axles or cv axle seals at the differential
Front driveshaft u joint and possibly cv cup
That would be a semi complete rebuild
Which parts does your truck need?
Looks like everything is good except my sway bar bushings and my front passenger axel and a differential seal I believe
What’s wrong with the passenger cv axle shaft? Boot torn and grease flung?
Which seal is leaking?
