fixt
- November 15, 2010
- North Carolina
- 1996 5.0L XLT AWD
I'm in the process of trying to drop the fuel tank to replace the fuel pump. Its a 1996 XLT with a 5.0 L.
I'm stuck at the fuel filler release. It will NOT release. I've washed out the accumulated crud to the point where the release tab will rotate and the fill line will rotate within its confines. I can't push in on the filler line at all and I can't get the tabs to release at all. Simple is not the same as easy. I really hate the ford connectors and I wish it had a simple hose clamp, but no, it had to be one of those weird Ford connectors.
Just to verify, the tabs are supposed to release away from the tank, right?
Any good tips or tricks to get this off?
I fought it for 2 hours today and will try it again tomorrow.
Thanks for the help, I really need it. I've got to get this thing going.
Background: I megged the fuel pump at the relay and it showed 6 Mohm to open bouncing back and forth. I have 12volts at the relay base.
The pump did not come on when the key is turned to on. I'm pretty satisfied it is the pump, which dies quietly in its sleep.
