- June 16, 2003
- Humboldt, KS
- 2000 Mounty
We have been driving the Mounty quite a bit, drove about 125 miles to KC for weekend holiday at parents. During the return trip home, about 30 miles into the trip with 1/2 tank+ fuel, the engine stalled, then picked up again. This resulted in a horrible thunk from torque converter, as you can imagine.
It happenened again, so I pulled off and looked things over--no CEL, nothing awry, so we headed off again.
We made the trip back, barely. I must have pulled off 6-7 times looking for anything I could think of. It seemed to run good for a while after we pulled over, then start cutting out again.
I noticed when the engine dies--my air fuel ratio guage goes "lean" -- in fact drops completely off. This leads me to believe it is a fuel delivery problem. I would think if the ignition was cutting out, I would see "rich"
I had swapped relays on the 4th roadside check, it made no difference.
Also, it seems to get worse as the tank is getting lower---ok---fuel pump.
Not so fast. This is a BBK 255lph fuel pump, which came with a Powerdyne supercharger kit. It is only 2 1/2 years old, and only has 10,000 miles on it.
I really do suspect a bad pump, It might be my imagination, buit it doen't seem to "whine" with the same pitch when I first switch on the key.
So, I guess I am asking for second opinions.
I have yet to drive with the scantool running, we were a bit loaded down and crowded.
heater core--now this.
