I have an (extensive) background in electronics and computer repair, often board level. This would not be very hard to attempt on your own if you have any soldering experience at all, and it's ok if you don't.
The key is to use a lot of flux... And high quality solder.
My wisdom I offer, however, is that if some of the board is taking a ****, you have no way to tell (((
unless you give it a serious check-over that most professionals would only be able to do in a way that you can now bet your reliability of said PCM on)), what that component may have taken out
along with it. You will come to find that frequently, when one part goes, it takes others with it, depending on what circuits are fused and what are not. And how much current that part of the board is sucking up vs other parts. You never know unless you truly do 100% know, and I don't think it's safe to say you could guarantee it will be reliable if you only replace these components and check for the obvious. anything that would really be worth spending the time, versus just pissing time away that you'll never get back cuz it may not solve the problem when you're done, anyway. And time is valuable, right?
That being said,
what I would do:
-Attempt to solder it myself with new components, because it's a nice big trace with easy to solder pads/contacts.
-Check common voltages + resistances with a multimeter to ensure it isn't totally ****ed beyond repair after I soldered it because I was impatient
-Plug it in and see if it works, and if so, for how long. May last the next 10+ years in this condition. may last 5 mins. may not even work. who knows, right?
-Be 100% prepared to buy a new one or take this one to a professional and know damn well my repair is a fix and less of a comprehensive repair, even though we gave it our best shot.
-Hang up a set of fuzzy dice because now we're gambling our reliability
What someone more responsible than me would do:
-Go get it professionally repaired because a professional would go in depth with a thermal imaging camera and have more tools at their disposal than I ever would on a DIY level, and be able to have them mostly if not fully guarantee the work, so I can trust that it doesn't have to be opened up and ****ed around with again.. to save myself massive headache. They will likely also catch anything you would probably not have noticed, that may have been ready to take the rest of the board out for all you know.
-Receive my PCM
-Plug in my PCM
-Forget about it for the rest of ever and just drive the damn truck without worrying lol
I am not responsible though, despite being experienced enough to do things the right way the first time. And I like instant gratification because I, too, am human.. So do whichever, really. You have been warned! Lol. And best of luck.
