Exploderpilot
- November 7, 2003
- Nuevo, CA (where?)
- 07 Titan SE
My favorite remote turbo setup is on an infiniti q45.
because it's the easiest and most sufficient way of obtaining true horsepower without having to build and overhaul a entire engine with a bunch of parts that will equal out to well over twice the cost of a homegrown turbo set up...
BTW Audi S4 00-02 my dream european car has a twin turbo v6 with 250hp stock...and can be modified to 500+ hp with a chip, race gas, and a upgraded turbo system...so in other words turbo is the way to go...
twin turbo 4.6 mustangs put out 800+ horsepower to the wheel try and get that with just a supercharger and a little port work not going to happen...unless you spray it too...
X2. Plus Teksid blocks holds a lot more power than a stock 2V or N/A 4V block will hold. Forged internals, etc., add to the Terminator's potential from the factory.Do You understand
1 thats a cobra, not a mustang... Cobras came with alot of extra goodies over a mustang such as a stock 4.6L DOHC Supercharged engine, upgraded trans, diffy, and 39lb injectors......
2. That was not just a stock engine with twin turbos they noted headers a custom intake, fuel rails and bigger injectors, twin blade throttlebody, also come on 110 octane gas i bet you run that every day at $6.62 a gallon
As for the second link, they are quoting power from the flywheel not from the rear wheels. I'm looking at a dyno sheet of a stock mustang GT makeing 223 HP 257 ft-lbs at the wheels on the mustangs forum. so 300 hp stock is kinda a little off
BTW it's Ford Mustang Cobra just for future reference so technically it is a mustang
The boost output of a S/C is limited to the revolutions of the pulley in relation to the motor. You can do a pulley swap to increase boost, but you are still limited the same way.
The newer technology in the centrifugal S/C's puts them w/ in reach of what a turbo can do, but any S/C is still causing some degree of parasitic loss.
The boost from a turbo can be changed w/o necessarily having to change any physical components. Going w/ twins instead of a single turbo will usually increase the lifespan of the turbos as they are sharing the work.
That being said, I think turbo is the cooler way to go and has more potential once you've done the install, but that's just my $.02.
I didn't take it at that, just giving my inputI'm not trying to bring down turbos in any way, infact i love tubros. All i'm saying is superchargers make big power too.
I don't think they make 800+ hp with out alot of other work done to them. Besides that i don't think the engines internals, trans, or axels could handle it for very long. Seriously you should stop just throwing out numbers like that. Alot of things you're saying just arent true, and you're probaily confusing people.
That and there are superchargers that can push the same psi as turbos they just sap power from it running on the belt system. But its really not all that much. Turbos have more problems with heat and such, just something to think about.
Actualy
A Mustang is a V6 car that all the rental car places have
A Mustang GT is the V8 car
A Mustang Cobra is the V8 supercharged car (this is a SVT car)
Obviously SVT cars have alot more upgrades than just some bolt ons, they are completely built for speed in just about all aspects.
Its like saying oh that F-150 out there can run 11s and not saying it was a ford lightning. Or hell i could say i'll race you in my VW golf and bring a Golf GTI W12 (thats right a golf with a twin turbo w12 0-60 in 3.5 sec.). How bout you be more desriptive when posting and that would help save people from confusion. thats what i'm trying to get at. i've said it like 5 times now.
And the teskid 281ci block is just as strong as the iron block they can handle more than 1000hp from factory its the pistons and rods that cant take the abuse from factory(well the boosted 03-04 cobras are setup with strong internals)
