1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
189K on my '98 5.0L. Finally got to replace the ball joints; upper were shot but the lower still had life in them. Fuel pump done a year ago. The usual coolant leak from the passages in the timing cover repaired a while ago. Radiator replaced a few years ago. Just like in any other Ford with the 8.8 rear diff, the ring/pinion gears are noisy and will be done at some point. Sway bar links may need replacement (for a second time). Minor leak from rear engine seal, responsible for 1qt loss between oil changes, which I won't touch until it gets a lot worse. Slight degradation in (the very poor to begin with) MPG; may merit replacing the original O2 sensors at some point. This thing will still be going strong when the 2015 Edge that we recently purchased bites the dust.
