FOR SALE ON EBAY - http://cgi.ebay.com/ebaymotors/Ford...004QQitemZ140217925975QQrdZ1QQsspagenameZWDVW
My name's Josh and I live in Dothan, Alabama. I've owned the truck since November, 2003. It's a 1992 Ford Explorer XLT 2WD. I started with basic upgrades and modifications like new paint, clear corners, tires, and wheels. It then turned into a constant work in progress resulting in what it is now.
It's curent state:
Specs-
Exterior:
Black metallic paint
Longtek brush guard
35x12.5" Dunlop Mud Rovers
15x8 Rock Crawler 97's
Sylvania Silverstar 9004 headlight bulbs
Clear corners
SRB 6" fogs
Taillight guards
Removed front valence/license plate holder
Custom shorty antenna
4' fiberglass CB antenna with custom mount on T/L guard
Herc'd door jambs
Bedliner'd rockers
Cut front bumper, bedlinered both
Painted grille
Tint
Curt Class III hidden hitch
Interior:
All-Weather floor mats
Leather steering wheel cover
Pioneer DEH-6500 head unit
Infinity Reference 5x7's in doors
(2) Infinity Reference 10's in a sealed enclosure
LA 1000W Amp
Uniden PRO538W CB
Suspension:
Front -
Custom SAS with HP Dana 30 from a Jeep YJ set up for spring over axle
BTF YJ SOA perches
Pro Comp 2.5" lifted YJ springs
BTF shackles
Warrior spring and shackle hangers
Custom hanger mounts
F-250 shock towers
Rancho RS5000's
Rough Country drop pitman arm
BTF crossover steering bracket with DOM links and heim joints
2" Slanted Body Lift
Rear -
Spring over axle with weld on perches
Warrior shackles
2" Tapered Blocks
Pro Comp ES3000 shocks on swaybar brackets
Homemade swaybar extensions
Relocated brake line with custom bracket
Drivetrain:
4wd transmission swap with electric transfer case that is now manual
KKM open element filter
Flowmaster Cat-back with Original 40 Series swapped in
Single Magnaflow high flow cat
Summit Manual Cutout after Y pipe
EGR delete
Motive 4.56 gears w/ Mobil 1 synthetic gear lube
Powertrax No-Slip locker
Skyjacker SS brake lines
What it was:
Then...
Then...
Then...
It's curent state:
Specs-
Exterior:
Longtek brush guard
Clear corners
SRB 6" fogs
Taillight guards
Herc'd door jambs
Bedliner'd rockers
Painted grille
Tint
Interior:
LA 1000W Amp
Uniden PRO538W CB
Suspension:
Front -
BTF YJ SOA perches
BTF shackles
F-250 shock towers
Rancho RS5000's
Rear -
Warrior shackles
2" Tapered Blocks
Drivetrain:
EGR delete
What it was:
Then...
Then...
Then...
