Jon And Sheri's Vitamin D Wagon | Page 43 | Ford Explorer Forums
O my
Those bushings are a PITA but I got em :)
I hung the new shackles and called it a night because I had to make a last minute winning bid on a 1946 Singer model 15 sewing machine with attachments.
Pictures for today
I need to take the shackles off and paint the frame a bit
Hrmph! Needs more white :D
Why do you have a Class III hitch? to cut down on your departure angle?
Is the Singer a walking foot model? You need a walking foot to sew your new canopy.:cool:
Yeah, it is a walking foot machine.
Hopefully my lovely bride can use it to make me some new panties too.
The hitch was a simple rear tow point.
Tough chick, don't mess with her!
baggie for me thanks
Well, for your entertainment and viewing pleasure today we will fix what was screwed up yesterday.
Yup, if I had actually crawled under for pictures I would have noticed this.
While pressing out the old bushing I smashed the passenger side backing plate for bushing support.
The only excuse I can give is I was very tired. I barely managed to even get the press-c clamp thingy up in there.
Anyway, this needs to be fixed so I grabbed a chunk of .120 2x3 , cut a hole on my drill press and cut out a bracket to shape
got it to fit
Cleaned it and the surrounding area
Then I made a second plate to wrap the stock support
and plan to place it like this after the first plate is welded in place, and weld over it all again
Think this will work?
I think the "wrap" plate itself will probably be good once welded on.
you know Jon likes his panties Brazilian Style :p: :d
kinda interesting with the frame bushings i just knock mine out with a hammer and large screw driver :dunno:
Well,
I drove a big ol socket into the hole so it wouldn't warp, and bugger welded the stuff together.
Man my little walmart welder sucks.If it would feed wire consistantly I think I could weld with it, but it keeps pausing
I am not showing this until I grind it.
If it's still leaning after all this I'd just throw an add-a-leaf on the left side and call it done. :hammer:
I'd worry about the height of the suspension to the ground. Then adjust the body to the frame after the suspension is level if needed. The best ride and handling etc, will come when the heights from level ground up to the suspension are equal. The looks don't affect performance, and the body is easier to work with as you guys know.
Jon I'm not picking at you, I don't recall everything that you have done so far. I just pointed out the best general goal to shoot for.
Psst, you added more weight to the left side didn't you?
It looks good, now back together.
Well, it's all back together with a 3" block on driver side, 2" block on passenger side and still has a little lean. No change.
The combination of springy springs, and the weight of the transfer case-gas tank seem to be what is doing it.
So, f150 leafs and the bronco 2 gas tank mod are in order.
Stop working on this thing so much, and use it. :)
The plan is to drive it to Uwharrie July 1st.
Lots still left to do and so little time. But yeah I feel the same way,
If you swapped the springs around, then the frame is tweaked. No other explanation. Its no big deal.
Just means it's broke in for you :D
Jon, I think you suffer from OROCD
Off Road Obsessive Compulsive Disorder. :p:
You know he is just trying to make it as good as his Mountaineer.
(Pssst, 1st gens will never be that good. :p:)
