ford99_1979
- August 17, 2009
- Calgary, Alberta
- 2020 ST
Jon, do you still need any foam padding for the roll bars?
I run a foam fabrication shop and have CNC cutting capability. Which means I can cut anysize inside diameter with anysize outside diameter. You could even go with a round inside hole for the roll bar tubing with a square outside. Its all open cell flexible foam, so not the closed cell waterproof stuff. With that said i'm sure it would work fine and I carry 4 different charcoal colored grades.
Let me know if you are interested.
EDIT: here are some examples
