I got the toolbox all mounted tonight. It turned out good. Flat or satin black would have hidden imperfections better, but gloss was what I had and maybe it will be more durable.
I also replaced the door hinges on the drivers side. That took way to long.
Finally, I replaced the crankshaft position sensor with the new ford unit. It made no difference.
I also replaced the o ring on the fuel pump. The last time I had it out, the oring swelled up so bad I couldn’t get it back together without cutting out a small section. So I did, but then I would smell gas because it didn’t seal. So I got one at the dealer for $2. I am really fast at changing fuel pumps now. I can get it done in about 30 minutes flat.
So I still have this hard start issue. The idle is still a little wierd. I am not sure what to do. Probably nothing before my trip. However, some ideas maybe:
1. The wiring to the fuel pump. I can buy a whole wiring harness for that section new old stock. I might just do that so I don’t have to worry.
2. The engine harness. There isn’t much there, but I may just find a junkyard unit and swap it. I cleaned it up and check it over when I did the swap, but maybe theee is something in there not right.
3. I never checked compression. Maybe I still should to that. The passenger side is a pain in the neck.
