I learned a few things today and I picked up my heads. The machine shop was calling this a TSB- its not:
I believe it is just a post off of the ranger station:
I have read this over and over. Its a little wordy. 1995-96 Aerostars ran 93tm heads and Deep dish pistons and the early computer calibration. So my setup with 91 computer shouldn't be ran with the 95 style pistons and 95 style head because it will burn down?
I have no idea the source or the "ford engineer". So that doesn't really help. I am told lots of guys are running this setup with no problem- so I don't know why this would hold more weight than that.
So I called every machine shop that was recommended here and on other sites to get some other opinions and most recommendations were either out of business or didn't want to take on the work even in Denver. Blue oval performance is no more.
I did however take it to another machine shop in my town, and I actually got some answers! The machinist has been working in this industry for 40 years. He looked them over and said it was pretty common. He said sometimes the heat treat on the head doesn't do a good job of hardening and this can happen. When I explained it had new seats put in by another shop he wanted to see the receipt. When I showed him, he immediately said he knew the problem. Apparently SBI used to make a good seat made in USA. A few years ago they started being made in China. And now they suck. The guy said he had a couple do this before switching away from SBI. He said they dont even machine well.
When I told them they were loud and I took them back and the other shop said they pressure tested fine, but then hand ground the valve seats again- he said why would they need to do that if they pressure tested fine?
So I think this guy knew his stuff and was being straight with me. He said that was why both the intake and exhaust valves took a dump- because the seats are garbage.
He made a phone call and he can get me some repop 95tm heads and put these springs and valves in them- but he didn't know if my valves would be any good.
However, I may have a line on a set of 95TM new old stock heads, so I am going to see how those pan out. They will be here by the end of the week.
