- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
It will be fine!!
I had a red top optima once that lost a cell it worked ok until it didn’t I had 12
Bolts for starting but not 12.2 or 12.4 and when running everything acted normal running on the alternator…
But once in a while it would
Act like no battery hard to start sometimes did t want to kick over the starter solenoid eventually I found it was only
Holding 11.8… at the time my buddy was working at optima so I let him
Check it out they found it had one dead cell. That one was a bit tricky to sort out!
@Rick completed project huh? I am not sure how accurate that is. She still has lots of work to be done.
I still have so much to do! I need to install the doubler soon.Are they ever really "completed"? LOL This one looked close enough for me.![]()
So wondering if anyone has any ideas for a master cylinder that would work a little better with this setup. Thinking maybe a 1995 Exploder. Will it work if it is for an abs? Maybe @410Fortune or @BKennedy would have an idea?
I ran the stock Ranger MC on both my 1993 and 2006 Rangers with the Explorer rear disk brakes. The rear on the '93 may have been a tad heavy, but not a major issue. I didn't notice any issue with the 2006.I still have so much to do! I need to install the doubler soon.
I have been doing some brake trouble shooting here lately. I got a little surge when I hit the brakes at certain speeds. I think my front rotors are warped. I put it on the lift and the passenger one seems to have a little wobble. I think I will either turn them or put some new rotors on. They are not that old, but it seems like such a hassle to have them turned and have to wait. I also want to shorten the drag link and install a high travel lower tiered so the I have more clearance between the tie rod and the drag link.
While I am doing that, I think I'll add these:
When I am out in the deep snow and it really gets packed in the front end, the front brakes stop working for a pump or two. I think these shields would help. The stock ones are huge and were bent on this axle of course.![]()
Disc Brake Dust Shields, Galvanized Pair-Broncograveyard.com
New, improved disc brake dust shields. Made of galvanized steel. Designed to improve airflow. PAIR For the following trucks: 1976 Ford Bronco, 1977 Ford Bronco, 1978 Ford Bronco, 1979 Ford Bronco 1976 Ford F100 4wd, 1977 Ford F100 4wd, 1978 Ford F100 4wd, 1979 Ford F100 4wd 1976 Ford F150...shop.broncograveyard.com
Question for you guys- I have tried to do some reading and didn't really come up with a definitive solution.
Front Axle Brakes: I am running the 1977 front brakes. The rotors are 11.7". Stock is 10.8". So about 1" bigger. My calipers are 3" wide and the stock calipers are 3" wide.
Rear Axle Brakes: I am running stock 1995 Explorer disk brakes. I dont really know how to compare those to my stock drum brakes on my ranger. It is rear abs and the abs works perfect and I like it. So I dont want to mess with that.
It does seem to be a little heavy on the rear brakes. When I am going fast on the dirt and I stab the brakes going around the corner- the rear wants to come around. Or even going straight it will try to lock up. Its not like crazy obnoxious, just a little obnoxious.
