Lets talk engine packages | Page 5 | Ford Explorer Forums
So according to their data, I can gain 4-8 HP all the way through the power band by swapping to 1.7 rollers on a stock cam, not to mention the other added benefits like a cooler running engine (due to less friction.)
What about the spring size?
Well, spring size anyone, I'm putting my order together...
So what are the cam specs of that, the Jeg's site was no help?
Right here.
Exactct same cam as I posted in page 3 of this thread.
PART NO. 35-510-8
01 INTAKE MASTER 3628F
02 EXHAUST MASTER 3630F
03 ENGINE FW XE258HR-12
04 GRIND NUMBER FW XE258HR-12
INT
EXH
05 HYDRAULIC Y/N YES 14 DUR @.050 208
216
INTAKE EXHAUST 15 LOBE LIFT .3340
.3410
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO 1.60
1.60
07 MAX GROSS VALVE LIFT .533 .544
08 DUR @ .006 TAPPET LIFT 258 266 17 LOBE SEPARATI 112.0
18 ADVANCE 4
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS
@ .006 10 INT 19 58
11 EXH 67 18 DATE SETUP / /
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 108.0 INTAKE CENTERLINE
For a new engine or high mileage I'd change lifters. But I would not buy new roller lifters if the mileage isn't high. I don't want to pay more than about $200 for a new camshaft, and $50 or so should buy a true roller timing chain set.
I fortunately have the used cam which I had bought new for my 91 302 HO engine build. I think it will be a decent first cam for my project, I've already paid for it($180 then).
Hunt around for other cam recomendations, surely something else is more reasonable than $261.
So 208 intake duration and 216 exhaust, with a 112 lobe separation angle. I recall that being a cam that I mentioned sounds very good. The Ford cams are all over 220 duration on the intake side, which is way too much for our heavy trucks with automatics.
Mine is a 212/222 cam which may be a hair more than I need, but mine will be a testing baseline engine first. Regards,
I'm winning on an E cam on Ebay right now. People here have done it and it works. I'm also looking into 1.6 roller-rockers, I'm going to do the same set up he did for his with the 1" intake spacer, 1.6 rollers, I'm hunting valve covers now.
http://www.explorerforum.com/forums/showthread.php?t=189306&highlight=rocker+arms
I would like to do springs too while I'm at it. Unfortunately, nobody knows what size the springs are.
Does not Summit list a replacement spring for an Explorer 302? I would suggest doing the springs also, those should be done every 100k or so if possible, just like timing chains. Regards,
