gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
I have a 2000. How do you get the passenger side UCA back on the spindle? I've beat the crap out of the top of the UCA trying to get in into the spindle.
I've even tried putting the floor jack under the LCA and jacking it up and well as greasing the UCA ball joint. I can get it to work. Any help or advice?
Thanks.
I usually had a floor jack under the LCA, and used a rubber mallet to smack the UCA down while pressing on the bolt 'til it slid through.
Thanks alot for the right up MountaineerGreen! My dad just came down with the ex from Montana for a visit. The inside of the tires have been wearing so we took it in for an alignment and the guy showed us the drivers side bj was shot. I picked up the bj from autozone for $40 and the press. Someone had screwed with the press though and the threading so we had to go back and get a different one halfway through the job. I had $20 on my rewards card so all said and done did it for $20. We only had trouble getting the knuckle off the UCA, i pried down while my dad used a mini sledge and it finally broke free. Also when I put the tie rod back on the castle nut just spun with the tie rod threading, not sure why but I just had to hold the threading while my dad tightened the castle nut with an open end wrench? Now that I know what im doing im sure I can do the passenger side in less than an hour. Thanks again man, saved us a lot of time and money.
you shouldn't need to remove the TRE for this job. I never had to.
Good luck removing the castlenut if/when the TRE needs replaced. If the thread of the TRE is spinning, then it sounds like the TRE is almost shot.
