jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
so got the motor pulled outa the 96 this weekend..i lost oil psi before i pulled it so from what i know a rod bearing usually wont loose oil psi because its a ""end"" flow..but crank bearing will,so there is no telling how many bearings or damage is done to this motor so its going in the parts pile.
plan is to use the motor outa the 94 as it ran fine before i blew the head gasket.so gonna replace all gaskets and use the new rockers/pushrods i put on the 96 motor.plus the lower intake,cam sensor and all wiring..hopefully there wont be any issues once installed in the 96 and i can get it sold fast to fund my new motor..the machinist said he would bump mine to front of the line the sec i say go..
my pops is outa town this coming weekend and i wont get the gaskets till friday so gonna be 2 weeks before i get the motor back in the 96..i still have some work to do on the 94 before i can drop the new motor in..it needs all new body mounts and gonna put a 5/8'' body lift on to clear my second intercooler.then dropping the rear 2'' and the front a 1''ish..till then stay tuned because that new motor should be done in about 3 weeks or a month now...
starting to pile up....
