Flashflood
- September 2, 2018
- Location
- Laramie
- Wyoming
- 2000 ford explorer 94 xlt
So I'm posting this in modified because I'm planning on m5od swapping my 00. Everything seems pretty easy the only problem I'm running into is ecu programming. What ecu's are you able to use. Can you use one's from a ranger sohc or will I just need to grab a vin from a explorer sohc any help would be appreciated. Or if someone could grab a p# that would also be great
