  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
MFT Black / Blank Screen
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I will try Voltmeter Friday morning
(Raining in SWFL today/tonight)
Nav. Screen dark about 1 week after purchase.
Sad part in SW Florida all dealers are booked for at least 3 weeks.
(Maybe our last Ford Product)
Called other dealers and NOT one called me back after they said they would.
Using the steering wheel cursor the dash display says Audio off and we cannot change it to any other setting , including the radio on/off button.
When I got that battery saver notification, I could not turn the radio on but everything did come back to life when I started the vehicle. It sounds like yours isn't. So while your battery may be low, the other possibility is a faulty APIM, Accessory Protocol Interface Module which is the 'brains' of the MFT. There are a few threads on that that you can find with the 'Search' function.
The APIM is located under the dash. Ford has extended the warranty on it to 5 years due to all the issues they were having with it.
BTW, it would be helpful if you added the trim level (Platinum) to your profile so it shows in the margin at all times.
I also merged your thread with this existing one for now.
Ford Explorer Fl
2016 Explorer Platinum
Measured Battery Voltage today
First thing in morning after car was off for 16 hours.
12.5 volts dc
Car Running
14.3 Volts Dc
after starting car
Display says "Powering down to save battery"
CD eject button works and screen says "NO Disc"
Load CD and Screen says " Reading disc"
Lower left corner " Entertainment " Beeps when touching screen"
then screen goes blank.
peterk9
Staff member
Moderator
Callsign
VE3
12.5 volts dc
Car Running
14.3 Volts Dc
after starting car
Try and see if another dealer can get you in earlier.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
12.5 volts dc
Car Running
14.3 Volts Dc
after starting car
I did a little research and a lot of people are saying bad battery cell.
I've also seen others say they have USB and 12V accessories connected and it causes it. If you have anything like an ipod/iphone cable or phone charger. Please disconnect and see if this helps.
Ford Explorer Fl
No electronics plugged in to any ports.
Looks like I will have to wait another 17 days for service, not much else we can do. all other Ford dealers are busy in SWFL
Checked each battery cell and they are all 2.2 volts each
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Have you disconnected the battery....let it sit for a minute and reconnected it?
Ford Explorer Fl
worked fine for my wife last night, but dead today.
Only 16 days to earliest appointment available in Southwest Florida.
Robert Lau
kailua
2012 Ford Explorer
Hi all,
New to this forum and have had my Explorer for about 4 years. Love it, great car and my wife loves it. Happy wife, happy life right. Great experiences thus far until we need to get it fixed. Bought all the extended warranties and maintenance plan and had all the services done regularly. Then reality strikes when you need something fixed.
I won't mention my other horrible experiences with the local dealer but rather talk about the current one Im dealing with. We got the black screen of death last Wednesday when phone bluetooth, radio and Sync screen went. So i called the dealer and spoke with one of the lead mechanics and he couldn't figure out what the problem could be. Then he said he would leave a message with the service desk and the service manager to call me back the next day. I got no calls. So 3 days later I said, maybe I should call and so I did. I talked about the symptoms of the issue and also brought up the issue about the replacement ACM they told me takes 2-3 weeks to come in they were supposed to replace. 3 months later, no part yet, anyway, he needed to check on the part and ask about what the problem with the black screen so he would call me back the next day. Well, he didn't, so i called on Saturday to follow-up, he said parts dept had the ACM(idk why no one called me) and that I needed to bring the car in to check out the black screen. So I made an appt for yesterday. Took the car in early morning and they would replace the ACM(they called it an amp) and troubleshoot black screen. So, i called yesterday for the status of the repair. They said they replaced the ACM(how do you know it works with the black screen and no radio) and are doing circuit testing for the black screen, and will need the car to stay overnight to be looked at tomorrow. I told them my wife needs the car Friday afternoon so they need to be done, call me when it's ready. Soooo, i call in today(Friday) at 1:30 to find out the status. I spoke with service manager because Im already fuming, he said he would check and call me back.. Hurray, he called me back 10 minutes later. He said, they discovered it's the APIM and that they need to get the ES number off of the APIM but it's read through the screen(which is not working) so they'll have to wait till Monday to call the mainland(continental US) for further steps in troubleshooting the issue and if there's further information they need, he'll call me. So by now, I'm headed to pick up my car and I talked to the service desk. Attendant tells me when I can I bring the car back. I tell her, don't you have to call to find out further steps?? She said, "hold on, let me check with service manager". She comes back and tells me that they completed the first step which is call the mainland and troubleshoot the issue. So they determined it was the APIM. Second step is they needed the serial number off the APIM so they can order the right part and Ford can approve it. Mind you my car was there for almost 2 days. So finally I said, "you mean to tell me that after my car was here for almost 2 days, i need to bring it back so you can get the serial number of the part that needs to be replaced? Also, I'll need to bring my car back again when the part comes in to get it replaced?" She said yes
So I get home and log into My Ford and enter my VIN, Audio Accessory Interface Module $650.67.
You know, my wife has had Fords for 20+ years and have been going to the same dealer that long as well and receiving excellent service until they were sold. Everything went downhill from that point on.
We purchase these warranties and maintenance plans in hopes that our investment is working when we need them to and reliably. If this is the kind of service I'm going to get for paying thousands more for, I think I would buy something else but a Ford.
Anyone with any suggestions???
Robert Lau
kailua
2012 Ford Explorer
anyone with similar issues? especially with the APIM? Is it normal protocol these days to bring your car in, troubleshoot the issue, have them order the part, and come back again to install? Or does most dealers carry spare parts. I know there are parts depts out there
FordIVTteam
Official Ford Rep
Dearborn, MI
Ford Explorer
Hey Robert Lau,
The replacement of the APIM usually takes less than one day. The dealer may require more time due to parts on hand and scheduling requirements. The APIM is the brains of SYNC and is not always accessible as a spare part.
Shaay
Robert Lau
kailua
2012 Ford Explorer
Thanks Shaay,
what i didn't get is that they had replaced my ACM and while doing that, why didn't they just get the serial number of the APIM at that time. Instead my car was there for 2 days and when i got my car back, they said I needed to bring it in again so they can just get the serial number of the APIM.
peterk9
Staff member
Moderator
Callsign
VE3
Thanks Shaay,
The APIM has a 5 year unlimited mileage warranty on it. It was extended due to all the problems owners of the early year models were having with them.
FordIVTteam
Official Ford Rep
Dearborn, MI
Ford Explorer
Thanks Shaay,
You're welcome, Robert Lau. I understand how that can be concerning. Let's hope everything goes great from now on. Keep me posted!
Shaay
dmuscat
Michigan
2015 Ford Explorer LTD
One issue that went away for me in my corrective actions was that I had always left a USB stick in the USB slot in the car. The USB stick had music and finding out that the USB stick was too large (16GB) and the wrong format (NTFS should be FAT), once I learned from the IVT team that MFT has issues with leaving USB sticks in for long period of time will cause issues with MFT. when I pulled my USB stick out and processed a reset 6months ago, all my black screen issues went away and most of all my other weird MFT issues went away. Seems that an improperly formatted USB stick and the wrong size USB stick causes issues with MFT along with leaving a USB stick in the USB slot for long periods of time.
mikeol
2016, Explorer XLT
I purchased a 2016 explorer about 6 months ago. I'm am very unhappy with the touchscreen, it's difficult to press, laggy, and three times now it has randomly blacked out on my and didn't turn back on until I turned the car off / on.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum.:wave:
Have you verified that your software is up to date with version 3.8?
Press Settings on the MFT screen, then press Help and then press System Information. Then you will see CCPU S/W Version. It should show 3.08.15128.EA.10_PRODUCT.
If you have that version then the problem could be with the APIM (Accessory Protocol Interface Module) which is the 'brains' of the MFT system. Best to have the dealer look at it.
Good luck.
mikeol
2016, Explorer XLT
Thanks for your reply, I will check it out tomorrow. I feel there must be some issue with it, unless the touch screen is usually unresponsive (I'm use to a smartphone the touchscreen in my explorer operates more like an ATM.) But, the blackout thing must be an issue.
goodmank
North, VA
2012 Ford Explorer LTD
So my wife and I have a 2012 Ford Explorer 4WD Limited and we just started getting the Black Screen of Death. After reading this thread just found out that the APIM is probably 99% the issue and that Ford extended the warranty to 5 years unlimited mileage. Unfortunately, 5 years was up 2/20/17 and obviously today is 04/19/17. Is there anything we can do? I don't have $1000 to throw at a new APIM and it controls the backup camera and the navigation as well as any music at all. I have already spent a lot of money at Wynne Ford and Bowditch Ford replacing a ton of other parts and maintenance. Any help would be sincerely appreciated!!!
peterk9
Staff member
Moderator
Callsign
VE3
Have you spoken to either dealer about this issue to see what if anything they can do to help out?
goodmank
North, VA
I spoke to Wynne Ford who I have done a lot of business with and the service person told me there is nothing they can do because it is 2 months past when the extended warranty expired. Is there anyone on here that has any way of contacting someone higher on the Ford totem pole to possibly get some help with the cost?
R F9 Black Screen on MFT 2011-2016 My Ford Touch / In Vehicle Technology 12
R Latest MFT Update Failed - Black Screen 2011-2016 My Ford Touch / In Vehicle Technology 13
D My first MFT black screen after two months owning... 2011-2016 My Ford Touch / In Vehicle Technology 7
K MFT(Sync2) to Sync3 V3.4 Upgrade Minor Issue 2011-2016 My Ford Touch / In Vehicle Technology 5
G MFT Sync 2 to Sync 3 Screen Stays On While Car is OFF 2011-2016 My Ford Touch / In Vehicle Technology 8
deewan MFT trouble dialing using iOS 13 2011-2016 My Ford Touch / In Vehicle Technology 2
E Sync 2 with MFT failing. How can I cost effectivly upgrade to Sync 3? 2011-2016 My Ford Touch / In Vehicle Technology 3
J Similar compatible alternative to MFT? 2011-2016 My Ford Touch / In Vehicle Technology 1
D Gremlins in MFT 2011-2016 My Ford Touch / In Vehicle Technology 0
J Sync 2 MFT APIM Replacement / Repair 2011-2016 My Ford Touch / In Vehicle Technology 1
D MFT update trouble and help needed 2011-2016 My Ford Touch / In Vehicle Technology 1
D Anyone use the Waze app with their MFT 3.8 or 3.10? 2011-2016 My Ford Touch / In Vehicle Technology 12
I MFT Entertainment Unavailable / Off Message 2011-2016 My Ford Touch / In Vehicle Technology 7
O Restarting MFT using "Seek >> + Power" (also for Sync 3) 2011-2016 My Ford Touch / In Vehicle Technology 0
E 2015 MFT 8" No NAV - Upgrade ideas to get Android Auto 2011-2016 My Ford Touch / In Vehicle Technology 6
I Sync 2 w/ MFT - iOS11 iPhone Compatibility 2011-2016 My Ford Touch / In Vehicle Technology 15
9 2012 MFT w/ Nav - Stuck on v2.11 2011-2016 My Ford Touch / In Vehicle Technology 5
Jon M This is new...Sync/MFT issue 2011-2016 My Ford Touch / In Vehicle Technology 6
J Upgrading to 8" Sync MFT on 2016 2011-2016 My Ford Touch / In Vehicle Technology 5
Jon M MFT/SYNC/Nav issues 2011-2016 My Ford Touch / In Vehicle Technology 0
S MFT with Speedcams, how ? 2011-2016 My Ford Touch / In Vehicle Technology 3
B Samsung S8 Plus and MFT 2011-2016 My Ford Touch / In Vehicle Technology 4
Daheim111 A "how to" to not have problems with MFT ? 2011-2016 My Ford Touch / In Vehicle Technology 7
2 MFT Update V3.10 2011-2016 My Ford Touch / In Vehicle Technology 150
S 2013 Limited MFT forgot second key 2011-2016 My Ford Touch / In Vehicle Technology 3
S 2016 SONY MFT - weird behavior 2011-2016 My Ford Touch / In Vehicle Technology 7
M Cannot update MFT 2.11 2011-2016 My Ford Touch / In Vehicle Technology 26
A Downgrading from (8" MFT with Nav) to (4.2" non-MFT) 2011-2016 My Ford Touch / In Vehicle Technology 50
T USB Drive Application Error/MFT Crash 2011-2016 My Ford Touch / In Vehicle Technology 8
T MFT Screen touch points unusable 2011-2016 My Ford Touch / In Vehicle Technology 9
L Clever MFT feature 2011-2016 My Ford Touch / In Vehicle Technology 4
B MFT 3.8 IOS 9.3 sync drops connection mid call 2011-2016 My Ford Touch / In Vehicle Technology 0
Sgt1411 MFT v3.8 and iOS10 Issues 2011-2016 My Ford Touch / In Vehicle Technology 65
D MFT for South America - spanish (not Spanish Spain) 2011-2016 My Ford Touch / In Vehicle Technology 5
M iPhone 6 SE and MFT 2011-2016 My Ford Touch / In Vehicle Technology 3
Z MFT Slow when iPhone paired 2011-2016 My Ford Touch / In Vehicle Technology 1
M MFT update question around versions 2011-2016 My Ford Touch / In Vehicle Technology 2
B Want to upgrade from 4.2 to MFT 2011-2016 My Ford Touch / In Vehicle Technology 11
C MFT in german 2011-2016 My Ford Touch / In Vehicle Technology 6
fyrfyter612 MFT problem...anyone else? 2011-2016 My Ford Touch / In Vehicle Technology 0
P Nav stopped working after MFT update 2011-2016 My Ford Touch / In Vehicle Technology 23
F MFT automatically switching to phone Yellow menu 2011-2016 My Ford Touch / In Vehicle Technology 2
1 MFT 3.8 bug and downgrade to 3.7.11 2011-2016 My Ford Touch / In Vehicle Technology 36
G Buying a 2012 Explorer - Nervous about MFT Issues (please advise) 2011-2016 My Ford Touch / In Vehicle Technology 7
N Responding to Text Messages via MFT 2011-2016 My Ford Touch / In Vehicle Technology 1
S SYNC MFT - Interesting USB Input Discovery 2011-2016 My Ford Touch / In Vehicle Technology 2
S SYNC MFT - Browsing Music vs Files 2011-2016 My Ford Touch / In Vehicle Technology 2
T MFT Performing Scheduled Maintenance Again... 2011-2016 My Ford Touch / In Vehicle Technology 3
blwnsmoke Upgrading from MFT/Sync 2 to Sync 3 2011-2016 My Ford Touch / In Vehicle Technology 198
S Sync MFT Browse Memory for USB 2011-2016 My Ford Touch / In Vehicle Technology 3
Similar threads
