Ok, here's a little update. I've been rushing to get it all taken care of before we leave to Cali this Friday. I need to have her all ready to go and on the trailer Thursday night.
She sat at the dyno shop for a full week. They finally go around to looking at it. First, they found a huge exhaust leak on the driver side header. The TM header design is a two part design, and the gasket sealing the two parts was completely toast. The two parts weren't tight causing the gasket to fail.
Got that fixed and threw on the scanner. No codes, other than my missing fuel tank sensor. Fuel trims looked perfect...everything was perfect! We thought we were all done. So I take it for spin around the parking lot. First few passes are just fine so I turn around to pull back in the shop and the popping starts again. Heath, the dyno tech, heard it this time and once again said it was running lean.
So, on the dyno it goes so that he can log some real time data. He finds that cylinder 4 is running rich, which in turn is causing the computer to compensate by cutting the fuel, causing it to run lean. He suspected a faulty injector. But later found that the spark plug wire to that cylinder was chaffed in 4 different places. So #4 was getting an intermittant spark, causing it to run rich!
Wow, what a difference in power! It actually runs good, I can't even believe it.
So, I told him to hold off on the Xcal2 for now. I want to get used to how it runs now and make sure it stays running good for a while, and then get the Xcal.
Now for the other drama, the alignment. It's at the shop right now so I don't really have an update. I tried to pull the coil spacers off this weekend, but apparently I didn't have the necessary tools, I couldn't loosen the nut holding the spacers down. So the shop is taking off the spacers and realigning it. I may even need new shims all over again. What a waste, friggin Dana 28. There is no way it is driveable how it currently sits though.
