danandkimmccoy
- December 7, 2023
- Madison, In.
- 2007 Ford explorer 4.0
Hi everyone, I have a 2007 explorer with a 4.0. I have had a check engine light on for a fuel cap leak. I replaced the cap with no help. I looked under behind the filler neck and found a small vacuum hose that was brittle that had a small white vacuum type connector with a cap on it. I cut the hose back to reinstall the end piece, but the hose had a bigger end that the connector went on. I was going to get some hose and adapter pieces to make it work...but I lost the little white end connector. I have searched and even went to the dealer, and they can't tell me what the part is called so I can order it. I pray someone can help me.
Thank you and God bless.
