No Spark on Rebuilt 4.0 | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Turdle
The Lowrider is a little higher
Staff member
Moderator
Humboldt, KS
2000 Mounty
I think the PATS and ECU need to be from the same car. is that what you've got?
yup. You might need to make a trip to the dealership to get the pats re coded. Or, you will need to find the pats module from the truck the PCM was from. And the keys.
Read the "everything you need to know about PATS" thread.
Check your fuses. I think the cigarette lighter fuse is linked with the obd2 port, but check them all.
Thadigus
Goshen, IN
2001 Explorer Sport Trac
So how exactly do we know that PATS is the problem?
koda2000
x
If your problem is still "no spark" then PATS is not your problem. PATS only turns off your fuel injectors. It has nothing to do with controlling spark.
Thadigus
Goshen, IN
There is no spark and no fuel injectors
