removed roof racks | Ford Explorer Forums - Serious Explorations
removed roof racks
Whats the best way to cover the holes? Should I just go buy a replacement bolt from home depot to get it flush since if i use the originally ones they will be sticking up. Or should I use bondo or a similar substance to cover the holes?
they stick up very slightly.
Some one had the great idea to just out some studs in there. You know just the threaded part.
I am 5' 7" and cant see the roof any way so I just put the screws back in.
who me ?
It says right under my picture :confused:
Mazzasec, if u have touch up paint, u could paint the top of the bolt so it blends in better, just a thought
Also, after you install the stud and sealant,
you can get 2 Chevy Tahoe "luggage rack delete" kits from a chevy dealer. With it, and a little modifying, you will have a 3/16" high long black strip where the stock racks were. Use a 5/16" forstner bit http://www.hectorshardware.biz/shop/product.asp?dept_id=72204&sku=321039&
to bore a holeHALF WAY into the Tahoe strip, where the mounting posts are.
the double sided tape will hold it down real tight-so the strip makes a cap for the holes.
It fits real nice, and tapers down on the ends for a flowing fit.
its kinda hard to tell but just put the bolts back in...its hard to tell really. I mean i notice them all the time but then again i'm 6'7" lol
attachment.php
the screws really are not that noticeable.
attachment.php
do you know the size for the set screws ?
How easy is it to take the roof rack apart on the 2002 EB? I would like to repaint the metal parts:)
Very. There's howto's somewhere here. Did it on my explorer, took less than an hour.
