- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I understood what you were thinking Dale, you will get it running okay until the rebuild. You are right to avoid turning the crank, but if the crank/cams are attached close to their TDC then it's no problem.
I have used a dial caliper many many times. They are very accurate in one direction for that one measurement. But, they are not easily repeatable to make multiple measurements while having to touch or move any surrounding parts. For thousandths of inches accuracy, any slight touch kills the accuracy.
A piston stop is so simple and very very accurate with a degree wheel to find dead perfect TDC. If you just use the same gentle force of contact to touch the piston in the same spot in the two directions, it's done. The only worry of error is how far from the center of the piston the contact is. Piston rocking in the bore affects the distances to points away from the center of the piston(parallel to the crank). That amount is very minor, it amounts to less than a degree.
Mark the engine(block etc) by the degree wheel two times, and the middle point is TDC.
