- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
I need to replace my rear axles and was thinking of maybe using the superior super 88 kit.
Some places said it only works with disc brake axles.. but other places say disc and drum brakes.. I've seen it listed for 95+ explores and other say 96+..
this is the more common info I've found..
does anyone know what the truth is? From what I can see, it should work fine on disc or drum brakes...
~Mark
"The Super 8.8™ Axle System features a 35% Increase in strength over stock applications. The system fits 1995 and newer Ford Explorers and Mercury Mountaineer 8.8 axle housings with disc brakes and drum brakes. The kit comes complete with the following: Two USA-made 31 spline 4340 chrome molly axles. The axles feature a thicker flange and increased radius to the body for a real strength increase for those side hill moments. This design provides more strength than some aftermarket designs that only increase the thickness of the flange. Two heavy-duty machined axle retainers with spacer rings. Complete set of 3/4 ton Timken Roller Bearings™ and Seals. Two C-Clip eliminators, Ten 1/2-20 threaded studs and two axle badges to show your Superior pride. The Super 88™ Axle System requires some cutting but no welding. On average it can be installed in your driveway in under 2 hours."
~Mark
