Ok I'm planning to build led arrays for my brake lights and I allready have a design in mind. My question Is this, I need to make the array capable of two different brightnesses for the brake and for the night running lights. The easiest way I can see to do this is to run the runninglights off of a resistor a d then give the full 14.4 volts for when I hit the brake. Is It safe to run an LED at lower than its rated current? I will have the array set up for 14.4
Thanks alot
matt
Thanks alot
matt
