- August 1, 2008
- MO MO
- 94 & 95 XLT's
So... this off seasons mod is going to be on the T-case. The 1354 has been stout, and working well, but I have gotten to a point where I just need MOAR gearing! Since I want to keep the roadside HWY manners with the 4:56 gears, the obvious answer is reduction cases.
I have reached out to both Advanced Adapter's and North West Fab for this.
AA will build an Atlas II 3.8:1 for the 4.0L 5 bolt trans, include the BroncoII/Explorer shifter kit. It will come with their mechanical VSS, and I have to order the pulse converter from Nevada Speedometer, for my electronic VSS setup. Here is a list of their build specs for anybody else curious or have been wanting to know the build specs for our rigs. The gear tooth size would need to be changed for your size gears/tires. Mine with 35's & 4:56 would use a 35 tooth. They provide a calculator on their site for this. http://www.advanceadapters.com/products/atlas2--atlas-2-speed-transfer-case/
ATLAS38 1.00 ATLAS 3.8:1 TRANSFER CASE
A25 1.00 INPUT. 25 SPL. LEFT DROP IS STOCK
ALDC-S 1.00 LEFT DROP CASE ASSY. STD ROTATION
301510A 1.00 ATLAS II LEFT SHIFT ASSY.
ALT32 1.00 ATLAS LONG TAILHOUSING 32SPL
301700 1.00 ATLAS CASE ASSY LEFT & RIGHT (FULL SYNCRO)
A1310CV 2.00 32 SPL.1310CV YOKE ASSY.
301506 1.00 ATLAS II SPEEDO HOUSING ASSY.
300620-34 1.00 SPEEDOMETER GEAR-LONG 34 TOOTH
303006L 1.00 EXPLORER/BRONCO ll SHIFTER
301603 1.00 SITE TUBE KIT-ATLAS
NWF is in the process of building a doubler box to be a direct bolt on to our 5 bolt trans. They have a list to sign up on just for us. I believe when they reach a certain number on the list, they will go into production. Now this box is way cheaper then the Atlas II, as it uses our stock T-case and a direct bolt onto the tail housing. They do offer an adapter that converts the tail housing to use any 6 bolt round T-case, such as NP205/231/300. The adapter is almost $500 itself tho.
If you use the adapter, you can choose one of three versions.... then run a case of your choice.
The Eco box cheapest option, where you build it using your own planetary gears.
The Black box.
The Titan Black box.
You can also run an atlas II with one of their boxes. I believe Diffwhackdaddy is running this combo.
http://www.northwestfab.com/NWF-BlackBox-Underdrive_c_7.html
I am giving NWF some time to see what happens with them. If they can get their doubler into production by say Febuary 2017, this maybe what I choose. Lot's to consider, lot's to save for, but lot's to look forward too.
The Black box.
