timtimtimajim
- May 29, 2014
- Colorado Springs, CO
- 1993 Explorer Sport
Nice!!
The rubber bladder stays after you fill the fluid up to the line
Regular mercon/dex for your 5 speed and t case, you do NOT need or want to use Mercon V
Cant wait to see what you do with the console!!
Thank you!
I was tempted to get rid of my console, but just couldn’t bring myself to do it!
Good day indeed !!
Curious to the placement spot of the resi. They are mounted firmly to the inner fender, by the cruise control vac tank, and that spot on the firewall you have it at now, doesn't that section flex easily?
As far as bleeding a "Pre-Bled" unit... Just remove the resi cap, crack open the bleeder a smidge, and gravity bleed it slowly at the trans for a few minutes. That's it, done.
For my manual swap, the electrical was the hardest part and took the longest. It was in a 2nd gen, so was a little different combining job 1 & 2 harnesses together to make a starting circuit. Hopefully yours is simple and straight forward and might only need a jumper to get crank & no harness re-pins to get spark.
Yay for Mom! That will help a bunch. I had one shipped from overseas from Redline Goods for mine. (They used to be a vendor here) Took months to get it, and they made it wrong. Ugh.
Glad to have a good day again!
The spot it’s in seems pretty solid. I think that’s where they mount from the factory maybe? I could be wrong though. There were two dimples on the panel that lined up with the reservoir holes!
Awesome! Sounds nice and easy to get this thing bled then! Thank you!
I think I have the wiring figured out, but I want to make sure I get it together before I put that information here in case I’ve got it wrong. And luckily no repining of harnesses from what I can tell. Seems like I can just jump two wires and it’ll work.
Ugh yah that’s the worst when a part you wait on isn’t right. The shift boot will be a nice touch with my console!
