288,000 miles
will not run
It was running (very poorly) when you took it in for exhaust work correct?
Now after new exhaust it does not run?
No codes?
I would check the compression after removing the heat guards
I would swap the computer out with a similar unit, same year is a MUST and see if it runs
When you had your exhaust done you should have removed the rear secondary cat converters, you only need the primary cats in the down pipes to pass emissions.
Do you still have the secondary cat converters?
Did the exhaust shop do a flow test for you? I know you say the exhaust is all new manifolds back, just want to verify this as th eblockage could be in the factory secondary cats or factory mufflers. The factory exhaust on these trucks is a mess
Also check the fuel pressure again, ensure the fuel rail is getting pressurized when you turn the key. In my experience these fuel rails DO bleed down back to the tank.
I have read and been told that the fuel rail is supossed to hold pressure in our 95-97 trucks even if it sits for days. Not one of the Gen II trucks I have worked on or work on often will hold pressure. It slowly bleeds down right after shutting the engine off.
All of them run fine and have fine fuel pressure. I think its a myth
My BII used to hold fuel pressure when I had the 4.0L OHV in there, now with the GT-40P 5.0L and OBD-II system it bleeds down same fuel pump (88 BII).
I have had a clogged cat converter on my truck, the catalyst broke loose inside the converter housing, chunks were pressed up against the pipe at the rear...it was HARD to diagnose, it would run fine for a bit then bog horribly.
I found the problem (this was a new high flow aftermarket cat, 3 months old) by listening VERY carefully under the truck with it running and in gear.
I have had a computer go bad in my truck, no codes were present, then there were many codes present after fussing with it for a couple of months (throwing parts at it)
Computer passed self test, engine barely ran
Computer was fried, exhaust shop left the key in the ON position and proceeded to use a MIG on my exhaust. This fried my PCM
new PCM from Advance Auto $60 and it ran perfect from then on.
I could actually smell electrical burning smell in my PCM
I have also seen personally 4 Ford PCM's completely fail, all of them OHV 4.0L's (OBD-I, getting older) all of them engine would run very poorly, make no power, barely idle. One of them ran okay but some driveability issues with EGR and 02 sensor codes.
Computer issues can be tricky to find, UNLESS you just swap the PCM with one with the SAME CALIBRATION CODE
This eliminates the PCM as the fault and you can move on
Check your wiring plugs
All that messing around you have done in your engine bay, intakes, etc...the factory wiring is very tight, it must be routed properly or it can get pinched/burned/loose and cause all sorts of issues difficult to locate
John may be onto something with the crank sensor as well, they are known to give fits, especially with a no start issue after a very poor running issue
As for the PCM problem, I usually borrow one from another truck or friend if possible before I go buying parts. Junk yards have known good PCM's for $60 around here, do not pay Ford $350 for a remand unit IMO.
Good luck and keep us posted
