- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
You might have a partially blocked radiator, not enough coolant, bad thermostat or a defective fan clutch.
Sometimes a code will get thrown if the band is either broken, or out of specification. It will also feel like the 2nd, and overdrive are a little delayed, and not positive feeling. Sometimes this could be mistaken for a rotted piston. First start with the band adjustments before replacing the pistons. There are other factors involved which could make the transmission have similar symptoms. Low EPC pressure could cause weak shifts. Bad sensor inputs from the VSS, BOO switch, and TPS could create a loss of overdrive, and TCC lock up. A bad governor could cause a 1-2 shift delay when it is cold. A bad modulator could cause shifting problems as well.
