- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
As I've been scratching my head on what to do about the pcv system, I found a fantastic write up.
http://mustangpartstech.com/Engine/BreathersandPCVDelete.html
I need to do this since my whole inlet side is pressurized. My only other solution would be to find another constant vacuum I could tie in to. This would mean one of 3 options..
1. Vacuum pump (No, I don't need any more pumps running, thank you)
2. Cut a hole in the exhaust and angle a piece of steel line to create vacuum and route it up to the engine bay. Could work, but I'd be pulling oil vapours thru my turbo....I don't really want to do that. Apparently slight vacuum in the crank case helps rings seal, but this is a complicated system as to much vacuum would not be good either. It would be a sealed system and a manual valve would be needed to be able to adjust crank case vacuum.
3. Do pcv delete with a catch can. This is my winner. Take the ball and spring out of my existing egr (dremmel the very bottom off the egr valve), run a hose from the egr to a T, then run another hose from the oil fill tube to the other side of the T. Then straight in to a vented catch can.
