Fuel pump is in, along with high volume/efficiency Fuel filter with braided line running to it.
http://www.explorerforum.com/forums/showthread.php?t=393262
No Leaks on start up. Made me happy.
Also, my Supercharged explorer has had an issue ever since the fuel pump was installed. With less that 1/4 tank there was always risk of stalling going around a corner too fast as gas would slosh away from the fuel pump inlet. I'm happy to report that I am not seeing this issue on my new truck. I'm not sure if I the fuel pump strainer isn't seated properly, or if it is the less expensive pump causing the issue.
The Aeromotive pump is quieter than the factory pump. I couldn't hear it at all when I turned the key for the first time. That caused me a moment of stress.
I'm waiting on some aluminum welding to be done. A frame mounting bracket is being made for my intercooler, and the slot maf mount is being welded to a chunk of 3 inch aluminum pipe.
Once that's done, I'll work on installing the intercooler, radiator, and pump.
The blow off valve is going to have to go under the truck also, before the intercooler (The MAF is going under the truck, about a foot after the intercooler). James said if I have the BOV after the maf, there will be a rich condition when it opens. The BOV can't be close to the maf either, or air turbulence around the maf will cause bad readings and the computer will have a fit (Translates to possible stalling). These are the things that are extremely helpful to know to avoid possible issues. The good news is that I have lots of cold side piping to make sure everything is done exactly to spec. The bad news is that there is more wiring under the truck (Tucked high in the frame rail, but still not ideal).
Installing the intercooler radiator and pump is going to take some work. I look at what StreetRod2000 is doing, and cringe at the work involved. Ideally, a radiator that was 24 inches by 7 inches would be perfect, and easy to install. Unfortunately siliconeintakes only has one that's 26 inches wide. This fits perfectly between the frame rails, but allows no room for the inlet and outlet. Too bad.
