- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Look at my balancer, see the aluminum toothed wheel? That is the trigger wheel from a used Explorer balancer, and it presses onto a ledge on the back of the balancer. The one wide tooth, marked in the picture, that is the TDC for the crank sensor on the timing cover. So there is just one signal every revolution of the crank. I don't know anything else about the signal, but hopefully some of the aftermarket companies will. If you could confirm that the signal is alike, you might adapt an aftermarket crank trigger to a common balancer.
