will this lift fit? | Ford Explorer Forums
will this lift fit?
SBJ420
Windsor NS
95 XLT
jeep Cherokee
rear add a leaf and coil spacers
Can I put this setup on a 94 XLT?
the leafs are the same width, so i think they'll work, but the front end is different, the coil spacers for a cherokee go around the bump stop so they use teh bump stop for alignment and stability, so i don't think they'll work...check out the f150 spring seats
thats not really a lift, its just a spacer and add a leaf, or basically it will bring you back to the ride height you had when the truck was new.
FROADER said:
Why don't you get rear AAL and coil spacers for an explorer?
because I can get these for free.
I think what I am going to do is leaf over but I cant seem to find on this site what I will need for the front. I know I will need new coil springs but there must be more than that. Any info would be great!
FROADER said:
Well, the SOA will get you 5"-6" so you'll need a 5"-6" lift for the front to make it even out.
But other than Coil springs what would I need to make up for that 5 - 6" ? this is a 94xlt
Drop down brackets. It's all included in a lift kit. Axle pivet, swaybar, pitman arm etc.
