- September 6, 2006
- South Central PA
- 1994 Explorer
- Callsign
- yosty
This picture was taken when I spend most of my day washing and waxing it with McGuire's 3 step wax system.... boy did it shine!
Stock sized BF Goodrich All Terrains & a brush guard from a 1998 - 2000 Ford Ranger
3" body lift and a home built bumper
New BF Goodrich 33"x10.5-r15's
Put bigger tires on it (35" Super Swampers LTB's)
A broken front axle shaft resulted in a solid axle swap. Click here for the Solid Axle Swap build thread!
Changed my grill to a ranger one!
37" tires, rock sliders, and a winch
1994 Ford Explorer Specs
- 1979 f150 Dana 44 Front Axle
- 1989 F150 Ford 8.8 Rear Axle
- Wheels & Tires
- Dirty Life Canyon Race Matte Black
- First torque 10 - 14 ft lbs
- Final torque 18 - 24 ft lbs
- Cooper STT Pro 37x12.50r17
- 12oz Airsoft BBs each
- 1991-1994 Ford Explorer Front Driveshaft (Front & Rear)
- Front: explorer front lengthed. Double cardan (non greasable) centering ball spicer 10018440
- Rear: adams driveshaft 1310 joints. Double cardan centering ball (greasable) spicer 10018465
- Behemoth Drivetrain 1354 Doubler
- 1990 Ford Econoline E-150 Saginaw Power Steering Pump
- Yost Offroad Bracket
- 1990 Ford Econoline E-150 High Pressure Line
- 1994 Ford Explorer Return Line
- 3g Ford Alternator
- Front Bearing 6303 RS
- Rear Bearing 6000-2RS
- Speedometer Cable – Ford Aerostar - Atp part # y-869 speedo cable
- Steering Fix Bushing – JCRoffroad.com Part # PLYBSH
- Ruff stuff bushings: DAY MO2153 1.5"od x 3/4"id
- Tie Rod End Part # ES2233L, ES2234R, ES2234R, ES2027L
- Body mounts
- Rad support:
- A pillar:
- B pillar:
- C pillar: energy susp. 9.4104G
- Rear: energy susp. 9.4104G
- Brakes
- Front
- 1979 f150 factory brake setup
- Brake Caliper Hoses
- 1979-1987 GM 3/4 Ton (Skyjacker Part #FBL17 with Skyjacker Part #38AB Square Banjo, Angled)
- Frame to axle hose
- 1980-1996 f150 rear hose (Skyjacker RBL80)
- Rear
- 1989 f150 factory brake setup
- Front
- Parking Brake Part #’s
- Intermediate Cable # 1994 explorer drivers side rear
- Driver Side Cable # 1989 F150 drivers side rear
- Passenger Side Cable # 1994 Jeep Grand Cherokee passenger rear
- Old Man Emu by ARB CS042R
- Front spring eye bushing RB-237
- Rear spring eye bushing RB-131
- U-bolt 8" X 3 1/4" X 10" Barnes 150 lb ft
- Rear homemade below the frame mount shackle hanger
- Bushing m02240
- Shocks
- Front Part #
- A2060 – ADX 2.0 Adventure Series Remote Reservoir Aluminum Monotube Shock
- Monroe 34687
- Compressed 18"
- Extended 31"
- Rear Part #
- Monroe 34672
- Compressed 14.25"
- Extended 23"
- Monroe 34672
- Front Part #
- Manifold/Header bolt is 8mmX1.25 thread (Both Sides)
- 75mm / Quantity: 8
- 45mm / Quantity: 4
- Y pipe to the manifold is 12mmx1.75 thread (Both Sides)
- 50mm / Quantity: 4
- M5OD Bellhousing Bolts
- These are grade 10.9 bolts
- top four bolts : 10-1.5x60mm
- middle two bolts : 10-1.5x70mm
- bottom two bolts: 10-1.5x75mm
- Thermostat housing bolts
- 6mm x 1.00
- The part numbers for the metal plugs are Dana #219-3052 or Dorman #555-108 and as was mentioned you need three plugs to do the job.
- 5-760 Joint full circle snap ring lot # 123050a item # dsh-30stpa
- Winch rope retainer bolt
- M6x1.0
- Length 1.2mm
- 4mm hex key head
Factory explorer manual hub oring
- Napa # 727-2153
