Jakee
- May 6, 2006
- Huntsville, Texas
- 01 Sport
Well, this was my first complete gear install and I think it's a success. It drives but I do have an ever so slight noise from the rear when coasting. To put it in perspective, if the window is down you can't hear. If the window is up and radio off you can hear the rear winding down slightly. It doesn't sound like an alarming sound and this may be normal with all new bearings, new ring and pinion and new posi unit. I'll drive it for 500 miles easy and check the wear pattern again. I may have to add one more shim to the pinion depth if it get's worse.
