Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
I go thru them a lot since I clock close to 100 miles everyday year after year. I also plow snow on my driveway and neighbors sometimes, and I tow very often. All these things do not help bearings.
Also, few of those 10 or more were the cheap Chinese ones at the beginning of the ownership when I was just plain stupid. Also, probably few of the rear ones I had to replace prematurely because I did not torque the nut properly, it's critical on the rears, not so much on the front.
Break loose the axle shaft nut while the vehicle is still on the ground with all the wheels still on. If the hub were never replaced, it may be still glued to the knuckle from the factory. That may slow you down, even after you have all the 3 bolts removed (15 mm). To get better access to them, remove the axle nut, and push the shaft in, that will make a room for a short socket behind.
