Blacksheep Josh
Slinky+Escalator=Fun
- July 31, 2006
- Statesboro, GA
- '01 Ford Ranger, RIP 93 X
We rebuilt the E4OD transmission in a F-150 with a 302 in it. We installed a higher stall converter for the built engine and also installed a shift kit into the transmision as well.
the problem is that when put into Drive, the transmission acts really weird and almost won't shift, if it is at all. We thought it might have been a bad neutral safety switch being out of adjustment, so we adjusted it and it ran great, but only when we manually selected the gears.
When we put the transmision into 1 and 2 it runs great, but when we are at a stop and we put it into D it almost goes out, it'll pull but just barely. When we try to shift back down to 1 it won't go...
Any ideas?
Battery is currently disconnected so the truck can relearn everything. I wanna sya the new torque converter is a 2200-2400 converter, but that's whats required with the cam and pistons in the engine..
Thought appreciated!
Any ideas?
